Ive decided I want to lift my TB, Done a lot of reading here and at trailvoy, and this is what Ive come up with
MarkMC Full kit
MarkMc 1.5" Spacer
Z71 Springs
Bilstein HD Shocks
Am i missing anything?
Me007gold wrote:I was planing on doing the Bilstien HD's in the rear as well. Would the BDS's be that much of an improvemnet. For tires I was thinking about running 265/75/16's
Gordinho80 wrote:Like Bob said... what is your goal? What do you plan on doing with your lift?
Also... if you're lifting the rear and replacing shocks, you'd be a fool not to go with BDS 55619s or 95619s, at minimum.
HARDTRAILZ wrote:Mine is a DD and does trips to far off wheeling spots. Go all out and use it. The jaw drop factor you will see on tougher trails is worth it.
Mine is both my DD and my "Company" truck, I mod it the way I do because I have the confidence that things will hold up and if they don't I can have it fixed in a day or less.
