So front end surgery part 2 (3?) happened this afternoon.
A couple interesting things: First off, the Suspensionmaxx "1/2 inch" shims are actually only 3/8" thick.
Secondly, my UHMW, which I thought was only 3/8" thick, is actually 7/16" thick. Stacking it nets 7/8 instead of the original 3/4 I thought I'd get.
To make my shims I used a 4-1/2" hole saw to cut a disc, a 2-1/2" hole saw to cut the center out, then used a 7/16" bit to cut the bolt holes. A drill press made my life much much easier.
I used 3/8" x 2" Grade 8 bolts and nuts for replacements. The Rough Country front spacers don't weld the bolts in so I was able to knock them out easily and replace them. I don't know if this is unique to the RC lift.
Round 1: 1-1/4" shimming (2x UHMW + Smaxx shim)Result:
FAILURE.1-1/4" is the maximum amount the UBJ can take with my flipped UCAs. With the UBJ at max angle, the unbolted shims were snug against the perch, but I could move them around by tugging a little bit. Bolting the top mount in drew everything up about 1/8-3/16" and gave just a little angle back to the UBJ.
Fender height was 39" or so (32" tires) and hub-fender was near 25".
The driver's CV joint was useless at full extension. Bound solid and tried to move the motor when I turned the wheel by hand. No go.
Round 2: 7/8" shimming (2x UHMW only, removed Smaxx shim)Result:
SUCCESS. *7/8" shimming gives the UBJ a lot more breathing room. At full extension, the CV joints bind very slightly. I will continue to run this way as anytime I'm moving at full extension, I'm going pretty slow. But high angle CV joints are in my near future.
Fender height sits just above 38". Hub fender is 23-1/2". This is after driving around the block to settle the suspension.
Given my rear spring sandwich coupled with the the weight I normally carry, I can now go and hold my head high on the OS... for now I am perfectly
LEVEL.
