Do LWB/V8 brakes bolt onto SWB hub assemblies?
by fishsticks » Thu Jun 10, 2010 5:10 pm
The 17" vs 16" wheel post got me thinking...
My brakes are fine now, but have been through one "pad cycle." My personal rule is that I'll swap just pads only once, and the next time around do calipers/rotors. Call me superstitious.
Since my next change will involve all brake hardware, and I'm married to 17" wheels anyway, I'm wondering if LWB brakes are a simple replace mounting bracket/calipers/rotors job, or if the hub assemblies are different altogether.
Rationale: Bigger wheels/tires are harder to stop, why not get a little boost?
by bgwolfpack » Thu Jun 10, 2010 5:26 pm
Have you checked at say Compnine to see whether they're the same size or not? Good idea and could be true. :coffee:
by bartonmd » Thu Jun 10, 2010 5:32 pm
There was some talk about it some time ago on the OS... IIRC, rotors and caliper mounting brackets are different... Calipers and pads are the same... Everything else should be the same, so it should just require getting the V8/EXT rotors and caliper mounting brackets, then whatever pads you want... Also IIRC, nobody's done it yet, though...
by bgwolfpack » Thu Jun 10, 2010 5:41 pm
Good luck with that Mate!!
Top story. Man killed in Internet accident.
(7.56 KiB) Downloaded 247 times
by rgraboske » Thu Jun 10, 2010 6:44 pm
As was said, the caliper brackets and rotors are different. The caliper brackets are around $60 each from parts4chevys.com. I haven't done it yet, but U have the part numbers somewhere. I'll find them and post them here.
eta: barton, I spoke to someone on the OS who had done it recently, and said it was an easy bolt on. Again, I haven't done it myself yet.
eta again: It was lmmj on the os.
The part numbers are: Right 88964429 and left 88964427
rgraboske
by fishsticks » Thu Jun 10, 2010 6:47 pm
Is the difference in the front only, or are the rear brakes larger as well?
by rgraboske » Thu Jun 10, 2010 6:50 pm
fishsticks wrote:Is the difference in the front only, or are the rear brakes larger as well?
It's my understanding that the rears are the same
rgraboske
by fishsticks » Thu Jun 10, 2010 6:56 pm
Excellent. Thanks for the info! :)
by Philberto » Thu Jun 10, 2010 8:56 pm
This is a mod that I did back on my old Mitsubishi Eclipse. (the AWD model had larger rotors and 2-piston calipers as opposed to the single-piston ones on the FWD one) If it works on our vehicles, it will be a relatively inexpensive big brake upgrade. Good thinking, guys!
by Gordinho80 » Fri Jun 11, 2010 12:26 am
I smell a write up in the works....
by Trail X » Fri Jun 11, 2010 8:52 am
Gordinho80 wrote:I smell a write up in the works....
Someone has to DO it first!
But yes, whomever does it first should take pictures and do a nice article for ORTB!
by irishboy02 » Fri Jun 11, 2010 4:50 pm
Count me out...i can just barely clear my 15s as is
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Zero » Sun Jun 13, 2010 9:42 pm
I have an ext so let me know if u guys need me to check something or take a pic. I think the real advantage would be to find out of the front brakes from the ss can fit on our trucks.
by fishsticks » Sun Jun 13, 2010 11:42 pm
IIRC the SS brakes require 18" wheels....which is undesirable for wheeling. I could be wrong.
by rgraboske » Mon Jun 14, 2010 9:55 am
fishsticks wrote:IIRC the SS brakes require 18" wheels....which is undesirable for wheeling. I could be wrong.
IIRC, the spare tire on my 06 SS was 17". If the SS had sucked in the snow, I was going to swap wheel and tires from my '02, but it didn't, so I didn't.
Again, I could be wrong, but as I recall, the biggest diference between SS and non-SS brakes is the pad material. They may already have the EXT/XL rotors.
rgraboske
by Zero » Mon Jun 14, 2010 10:52 am
Ya I heard the ss spare was 17" as well, that when I started wondering if the swap would work. Getting the ss brakes on our trucks would be a huge difference in braking.
by JCrayton99 » Sat Feb 25, 2012 3:26 pm
Bump.
I was wondering if anyone ever swapped the EXT breaks on a SWB and if anyone ever looked at the SS breaks?
JCrayton99
Rank: Offroad Guide
