offroadTB.com • View topic - Wheels question
Wheels question
by TBLAZER_02 » Sun Jun 04, 2017 1:11 pm
I'm looking to pick up a set of Thunder rims and they come in 2 options
1 is a 17x8 offset 20 bore 78.1 ... the other is the same with an offset of 40.
My question is will either of these rims with the offset they have make it so I don't need to have a wheel spacer.
Website to wheels below
https://www.canadawheels.ca/wheels/fast ... der/W49350
Thanks for the help
TBLAZER_02
by Rickalicka18 » Sun Jun 04, 2017 7:24 pm
No, you need less positive offset. Factory offset is +40 I believe. 0 offset would be about 1.5". You'll most likely have to get something custom drilled for that though... that's what I had to do.
Rickalicka18
by Trailblazin Ahead » Tue Jun 06, 2017 5:12 pm
I have 1.5" spacers and a 0 offset on mine. 265/75r16 mts
Trailblazin Ahead
by TBLAZER_02 » Wed Jun 07, 2017 11:23 am
Thank you both for your replies I didn't think it would work but I had to ask.
TBLAZER_02
by mason10198 » Wed Jun 07, 2017 12:42 pm
You need at least 0 offset to run oversized tires without spacers. I went -12 when I did it.
I'm currently running -12 offset 17x9s, with 1.5" spacers and 35x12.5 tires.ImageImageImageImage
| Mason | | | |
by Rickalicka18 » Wed Jun 07, 2017 1:17 pm
Dang, looks awesome Mason! I'm glad the rigs back on the road. Would you be able to measure the clearance you have between the tire and balljoint for me? I want to upgrade to 33x12.5 next time I get tires, was wondering if my rims have enough offset to clear the balljoint
Rickalicka18
by Trailblazin Ahead » Wed Jun 07, 2017 5:43 pm
Mason are you on a body lift as well
Trailblazin Ahead
by mason10198 » Thu Jun 08, 2017 1:29 am
Yes, I've got about 4.5" total suspension lift and another 3" of body lift.
And Ricky, the ball joint clearance is about 2", just remember I'm running -12 offset wheels AND 1.5" wheel spacers.
| Mason | | | |
by Rickalicka18 » Thu Jun 08, 2017 9:25 am
Rickalicka18
by Trailblazin Ahead » Fri Jun 09, 2017 3:32 am
I'm running liftmeister 3" moog 8114s and yukon denali rear 1.5" spacers I wanna do the zone 2" body lift as well. just got my green filter and transmission cooler as well ordered
Trailblazin Ahead
by TBLAZER_02 » Thu Jun 15, 2017 1:48 pm
TBLAZER_02
by Rickalicka18 » Thu Jun 15, 2017 1:56 pm
4.5" in the back is possible. Maybe closer to 4" in the front. That's what mines like anyways. You get an extra inch from the stiffer springs
Rickalicka18
by HARDTRAILZ » Thu Jun 15, 2017 2:10 pm
You an get about 4 front if you eliminate all downtravel.
by Trail X » Thu Jun 15, 2017 2:13 pm
For ball joint clearance calculations, I hate dealing with offset, since there is another variable - wheel rim width.
Calculate the backspacing of the new wheels, and make sure its less than 5". 4-5" of backspacing is pretty much ideal. Just keep in mind if you get super wide tires on a narrow rim, you could also run into the ball joint, as it is also a variable.
viewtopic.php?f=14&t=26
The option you mentioned with an 8" rim and 20mm offset comes out to ~ 4.8 in of backspacing (check my math). If you're running a 265 or 285 width you should be ok, but you're getting close. Get up into the 305 and you might have issues. Depends on the margin of error that you're comfortable with making a decision on.
by HARDTRAILZ » Thu Jun 15, 2017 2:19 pm
Definitely agree with using BS not offset. but you can use this to see how changes affect things if you know offset and width.
https://www.1010tires.com/Tools/Wheel-O ... alculator#
by Rickalicka18 » Thu Jun 15, 2017 2:27 pm
Rickalicka18
by HARDTRAILZ » Thu Jun 15, 2017 2:30 pm
Mine was about 3.82 but I say 3 or so cause I dont want people thinking 4 is reality
