offroadTB.com • View topic - Possible Speedometer and Abs fix for gear change
by Shdwdrgn » Wed Dec 28, 2016 5:32 pm
Ah ok, so you didn't actually use my file in your truck then. I could probably generate a file for you with certain equipment disabled as long as I knew what needed changed, but it sounds like you found a working solution anyway.
So if you have 3.73 gears, why are you planning on putting in 4.10s? I assume you plan on going for much larger tires, like 35's?
Shdwdrgn
Contributing Author
by rScherzer » Wed Dec 28, 2016 5:52 pm
rScherzer
by mason10198 » Wed Dec 28, 2016 6:09 pm
No need for a body lift with 33s, I ran them for a while with nothing but 3" in the suspension
Edit: you do have to shave off a little plastic around the edge of the wheel well trim and the plastic bumper cover, but that's it
| Mason | | | |
by Shdwdrgn » Wed Dec 28, 2016 6:12 pm
I've done 95 across Nebraska with 30.6" tires and 4.10 gears... the truck ran perfectly fine, and I've made many trips down the interstate since then (usually not quite so fast). I honestly thought I would have more problems with my top end when I switched to 4.10s, but it's been one of the most useful all-around changes I have made. The only reason I asked was because I have seen others say that swapping 3.73s to 4.10s wasn't worth the effort, but it seems like everyone benefits from getting rid of the 3.42 gears.
Shdwdrgn
Contributing Author
by Shdwdrgn » Wed Dec 28, 2016 6:14 pm
Shdwdrgn
Contributing Author
by rScherzer » Wed Dec 28, 2016 6:36 pm
I have been stock piling cardboard to fabricate a bumper or two. It will be my first real fabrication other then a little trimming and stuff. It seems the 4.2 likes to be up in the RPM for cruising.
rScherzer
by Shdwdrgn » Wed Dec 28, 2016 7:00 pm
Well here, if you're making a custom bumper maybe my pics will help you for a reference...
http://sourpuss.net/projects/vehicles/t ... nt_bumper/
It was a long process, but totally worth it.
Shdwdrgn
Contributing Author
Return to Off Road Discussion
