HARDTRAILZ wrote:Offtopic a bit----but what is your lift? Everyone else can get aligned without custom control arms so your not being able to be done is odd.
I’m using 3'' lift. but the issue is that I have a negative camber is a little bit but is enough to see that is not perfect alignment.
So I would like modify the upper control arm to get the correct alignment.
I don’t know why is a negative camber must be positive for a lifted truck.
perhaps is something else but I can’t find what could be.
cheers
Jorge
