offroadTB.com • View topic - Front end clunking noise
by sicklife17 » Mon Jan 25, 2016 7:34 pm
So for a long time now there has been a clunk in my front end over bumps. I was told it's the sway bar links. And the struts were squeaky. So I finally replaced Bassicly everything and added a 2.5" lift. It is now clunking worse then before. I no that there was a part on the Blazers under the drivers door that was common to break and broke on my girlfriends Tahoe. She had the same sounds I'm having and I can't figure it out. Does anyone no what it could be?
sicklife17
by Jrgunn5150 » Mon Jan 25, 2016 7:56 pm
by sicklife17 » Mon Jan 25, 2016 8:17 pm
honestly sounds like the front end is about to fall off. And it's been like this for a while. I replaced all the sway bar links and bushings front and rear shocks( bilstien front skyjacker rear) z71 coils and a 2.5" lift in the front.
sicklife17
by Jrgunn5150 » Mon Jan 25, 2016 8:46 pm
So you're still rolling on OE balljoints and control arms and control arm bushings and tie rods? You really did struts, springs, and sway bar endlinks?
by Jrgunn5150 » Mon Jan 25, 2016 8:50 pm
I would suggest getting it up on jackstands with the tires still mounted and seeing if you can reproduce it or find any slop. You're just going to have to go out there, have someone work the wheel while you watch, and pry on the tires to see where it's coming from.
by sicklife17 » Mon Jan 25, 2016 8:58 pm
They guy I bought it from did the ball joint after that I'm not sure. I had it up on a jack and everything's seems tight and rigt
sicklife17
by SITKA4wd » Mon Mar 14, 2016 10:30 am
I am having the same issue. I have a stock 2006 LT and just did the suspension, sway bar end links and bushings. And I am getting the same clunking noise. Its not all the time, but seems to be over extreme bumps, and sounds extremely loose. This coming weekend I am doing all the ball joints, and tie rod ends. I firmly believe, at this point, its going to be the ball joints or control arm bushings. I will keep you updated what happens. But I agree its super annoying!!!
SITKA4wd
by HawkeyeC25 » Mon Mar 14, 2016 11:17 pm
You said you did the sway bar end links, but did you do the bushings in brackets that hold the front of the bar to the frame? (See upper right corner of the pic below - you can see the blue Moog ones I put in.) Other than what others have listed (ball joints being the likely culprit), you should also check the hubs, check that the CV shafts aren't flopping around, ensure the front axle isn't loose (any of this worse in 4wd?), and check body mount bolts.
HawkeyeC25
