After researching, I am a little confused on tire fitment, and would love to pick a few of your brains. A 30 inch tire fits with no lift, but apparently only a 31 fits with 2 inches of lift? If my figuring is correct, a 32 should fit with 2 inches since it only adds an additional inch on each side of the tire. If am correct in this thought process, I am looking at purchasing 275/70/18's and 1.5 inch spacers.
It should be noted, that the largest amount of "off-roading" this vehicle will see is the curb that I cross to pull into my driveway. I know that flex plays a factor in tire size, but if it fits on the ground, I shouldn't rub otherwise.
Should I be alright with these tires? Or will I run into issues with the width of them?? Thanks or all the help, looking forward to being an active member here!
