by Mirage » Sun Dec 13, 2015 10:11 am
M_C_U_02 wrote:Nice! Trying to plan out the exhaust myself.... I'm thinking side exit. Looking forward to seeing what you come up with...
I went with just a simple 90deg elbow. Painted black to slow the rust.
Mirage
by Aries » Sun Dec 13, 2015 11:01 am
Would you have a part number on that tail pipe?
Aries
by Mirage » Sun Dec 13, 2015 11:53 am
It's just a 2 1/2 OD pipe from my local parts store.
Mirage
by DirtyBacon04 » Mon Dec 14, 2015 12:47 pm
I have seen several ways to remove our front diff seal without a seal puller. Plus i've used seal pullers and never had much luck with them anyways. Well, I came up with this the other day and it worked perfectly. Drilled some holes on opposite sides of the seal, threaded in 2 eye bolts, put an allen wrench through the holes, then put the breaker bar behind the allen wrench, and pushed with my foot using the frame as the fulcrum. Nice slow steady pressure and this popped right out.
by mason10198 » Mon Dec 14, 2015 4:50 pm
Nice! Saving this in the "genius ideas for later use" folder :photo:
by DirtyBacon04 » Mon Dec 14, 2015 8:57 pm
Figured it was about time I replaced the rear lower control arms... the left side was frowning all day long and the right side more closely resembled a lazy lightning bolt than a control arm. Many Many Many trails have been seen by these arms and they dealt with the brunt of it all. Even after all that, the bushings are still in perfect condition.
by M_C_U_02 » Mon Dec 14, 2015 10:39 pm
Mirage: that came out real good. All business, no fancy tip, just pipe... looks sturdy... definitely looking to do something similar...
Looks like you welded a 90° sweep on after the rear exhaust hanger?? ..just forward of where the 'trash can' was?
M_C_U_02
by Mirage » Mon Dec 14, 2015 11:19 pm
M_C_U_02 wrote:Mirage: that came out real good. All business, no fancy tip, just pipe... looks sturdy... definitely looking to do something similar...
Thanks and yes it's just a 90 I stuck in where the can was cut. The way it turned out was purely by accident. I thought I would end up having to add in pieces here and there to get it where I wanted.
Mirage
by HARDTRAILZ » Tue Dec 15, 2015 9:34 am
Tried to fix the blower actuator, but the replacement had too short of wires, so need to get a different one.
by KingBird » Wed Dec 16, 2015 10:48 pm
Ordered a winch. I went with a TigerShark 13,500. It will more than handle the Bravada, and it will also be used when we load other projects on the car hauler, plus if I ever move up to a full-size, I'll be set.
KingBird
by Trail X » Fri Dec 18, 2015 10:54 am
Bacon, those look like mine did! What did you replace with?
by DirtyBacon04 » Fri Dec 18, 2015 11:03 am
I just replaced them with stock arms. Nothing fancy.
Truck actually seems to track better, too
by Anthony Hernandez » Sat Dec 19, 2015 11:25 pm
I taped off the fenders and sprayed a bondo brand rubberized undercoating spray and rustoleum semi gloss black over top.
by DirtyBacon04 » Sun Dec 20, 2015 2:06 pm
That looks really good! Your lines are way better than mine. I might spray over mine with that stuff.
by Anthony Hernandez » Sun Dec 20, 2015 3:07 pm
Thanks man. I got some .70 tape from oreilys, it worked well, but I had to follow the outward part of the flare for the edge. Inside was too much of a bitch man. I had like 1m stand-off from the truck too..overspray is rediculous with stuff
by Trail X » Sun Dec 20, 2015 10:03 pm
I like it Anthony! Why not carry it over to the rear bumper?
Is that the same stuff you used on your front bumper? That finish looked really good, better than my powder coat. I probably need to grab a few cans and redo my bumpers with it.
by Anthony Hernandez » Sun Dec 20, 2015 11:03 pm
Yes sir... Well I went back and forth between taking the rear off and possibly selling it, but now I'm prolly just gonna do it up too...I got materials for a rear bumper... Almost all of it... For now I'll paint it.. Prolly... I dunno... Finally have some time on my hands... Never know what might happen.
by Anthony Hernandez » Tue Dec 22, 2015 4:50 pm
Paint.
by Jrgunn5150 » Tue Dec 22, 2015 4:55 pm
The rubber undercoat in a can seems to work better than the truck bedliner in a can, in my experience.
by Anthony Hernandez » Tue Dec 22, 2015 6:30 pm
Fa sho do bro
