Mounted 4WD actuator onto AWD disconnect
by Beamer » Fri Aug 22, 2014 8:43 pm
Since the 12471636 AWD sleeve is on indefinite back order, I ordered the entire AWD Disconnect assembly. After installing the disconnect, I wanted to mount the 4WD actuator on the disconnect as it has the actuator hole plugged, but the mounting holes are drilled and tapped.
Pry the plunger out by using a screwdriver in the slot.
I removed the plunger, spring and shaft.
Cleaned out the hex hole.
Needed to cut the shoulder down where the actuator housing would go into the disconnect housing, I cut just behind the circular rib.
After cutting.
Then mounted the actuator to the housing, connected the wireharness and it works perfectly. This way it is firmly mounted in the original location and not just zip tied somewhere open to the elements.
Beamer
by DirtyBacon04 » Sat Aug 23, 2014 7:05 am
it's not showing a Service 4wd light?
Good work! I like the idea and creativity.
by v7guy » Sat Aug 23, 2014 8:33 am
Nice solution to avoiding the light
by Beamer » Sat Aug 23, 2014 10:08 pm
DirtyBacon04 wrote:it's not showing a Service 4wd light?
Correct, Not showing the service 4wd light.
Beamer
