by navigator » Wed Jul 16, 2014 7:11 pm
if I don't find something local that might be something to consider....
by DustinC1989 » Wed Jul 16, 2014 7:48 pm
Tracing down why my taillights aren't working. Top bulbs and license plate lights are out.
Circuit boards are good, wiring looks fine, bulbs are good and fuses are good
DustinC1989
by Chango » Wed Jul 16, 2014 10:18 pm
Bought my SS rear end today! And got the 3.42's out.[attachment=-1]uploadfromtaptalk1405563508259.jpg[/attachment]
Chango
by Moots1288 » Thu Jul 17, 2014 5:01 pm
I found out that the dashhawk does not work for 06 when trying to do CASE Relearn, it only works 08+ because they use CAN communication.
by c0a8l0v6i8n9 » Thu Jul 17, 2014 5:37 pm
I had a miss on cylinder 4. Pulled the coil and there was water. I guess it's time to add weather strip to the hood to keep the water out.
c0a8l0v6i8n9
by Eredin » Thu Jul 17, 2014 5:55 pm
I still have an idle misfire on cylinder 2, appears to be injector at this point, everything else has been replaced. :|
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by AA1PR » Thu Jul 17, 2014 9:24 pm
routine oil change to keep the ol girl purring
1966 Stevens M416 trailer too
AA1PR
by Gordinho80 » Fri Jul 18, 2014 11:44 am
Recently used my GMT to pick up my new toy! 1983 Suzuki GS1100G... my first bike...
Mario -
by Trail X » Fri Jul 18, 2014 5:38 pm
by Eredin » Fri Jul 18, 2014 5:58 pm
Eredin
by Trail X » Fri Jul 18, 2014 11:46 pm
Yeah, I'm going through the same dread, thinking that the replacement cracked, which is making me consider welding up my own mini headers...
by Blazintrails03 » Sat Jul 19, 2014 3:54 pm
Installed my trans cooler today. I think I did it right haha. Followed the line from the drivers side bottom of the trans and took it apart by the air box. Used the Hayden piece and hosed it together. No leaks as of now.
Blazintrails03
by Trail X » Sat Jul 19, 2014 6:53 pm
I don't recall which way is 'right', but they both work honestly. I intentionally did mine backwards from the norm, and I'm quite happy with it. Hotter fluid running through the aux cooler, and therefore it helps keep the radiator temps down a bit better.
by dvanbramer88 » Sat Jul 19, 2014 9:06 pm
the way my truck came from the factory is, Transmission -> Radiator -> Aux Cooler -> transmission. So that's the way that GM considers the "right" way. But honestly, there is good arguments out there for doing it either "right" or "Backwards" and it really comes down to personal preference, and what school of thought you want to subscribe to.
Backwards does keep the radiator temps down, and helps keep the load on the radiator lower. It should also keep the trans at a more constant operating temp. ( close to, or a few degrees behind the engine) But really either way works and is fine.
by navigator » Sat Jul 19, 2014 9:16 pm
I guess too if you don't have a cooler with the tstat in it if you run cooler first, in cold weather the radiator will help warm the tranny fluid up.
by mattrustable » Sun Jul 20, 2014 9:19 pm
I re torqued my wheel spacers today. After doing some random reading around, I read that I should re torque after 100 miles then every motor oil change. Well today I did after 1000 miles, lol, but every single nut was still at 100lbs. No shaving of metals and my wheels were easy to pull off with no kicking of the wheel. I will check them every other oil change just to make sure every thing is kosher
mattrustable
by chevycrew » Sat Jul 26, 2014 3:00 pm
I decided to sell mine? lol
by navigator » Mon Jul 28, 2014 8:36 am
is that a statement or a question?
by ErikSS » Mon Jul 28, 2014 10:54 am
Im betting on it being a joke.
by navigator » Mon Jul 28, 2014 11:13 am
Steve does like to joke, he had the guys on trailvoy believing that he was going to run 42's on his TB....
oh wait, he said he was going to do it and he did....
http://forums.trailvoy.com/showthread.php?t=86552
It is fun to go back and read threads like that again for a laugh!
