Water pump bolts
by rjwz28 » Wed Apr 16, 2014 6:53 pm
Hey, when I changed my water pump I was working with bad torque specs and broke the head off of the last bolt... where can I find new bolts other than the local stealer? I'd like to replace all of them since I know I overtorqued each and every one.
Thanks
2006 Trailblazer LS (stone stock, for now)
2003 Z06, H/C/I, Halltech, Kooks: 424rwhp at 97°F
2011 6.2 Silverado CCSB 4x4, 33s, MIT, tune SOLD
rjwz28
by KingBird » Wed Apr 16, 2014 7:03 pm
There are torque specs for water pump bolts???
KingBird
by ErikSS » Wed Apr 16, 2014 7:26 pm
I'm pretty sure there is a torque spec for most all of our OEM bolts. However I use the 3/8" wratchet... GoodNuff torque spec for water pump bolts. Lol I'm aware we have some torque spec fanatics on this forum. I tend to go by feel.
by rjwz28 » Wed Apr 16, 2014 7:47 pm
KingBird wrote:There are torque specs for water pump bolts???
Yes, 89 inch-pounds
Unfortunately, there is also a spec out there for 22lb/ft or something, which is wrong...
ErikSS wrote:I'm pretty sure there is a torque spec for most all of our OEM bolts. However I use the 3/8" wratchet... GoodNuff torque spec for water pump bolts. Lol I'm aware we have some torque spec fanatics on this forum. I tend to go by feel.
Yup, there are torque specs for damn near everything...
However, now that I've sheared off the head of this bolt and have to replace it, does anybody know where I can get more???
rjwz28
by TBYODA » Wed Apr 16, 2014 8:30 pm
rjwz28 wrote:However, now that I've sheared off the head of this bolt and have to replace it, does anybody know where I can get more???
Take one of the others out (hopeful not breaking again) and go to ace hardware or other such store and match it and get a metric grade 10.9 version. I am sure you should be able to find something that will work. Most hardware stores have those thread matching boards to help size it up.
by rjwz28 » Wed Apr 16, 2014 8:44 pm
I was hoping to replace with OEM (or equivalent) but that's a good idea... I found the bolt size in another thread but haven't yet come up with a source for the bolt, so I may have to go that route
rjwz28
by KingBird » Wed Apr 16, 2014 9:15 pm
Wow, I'm in the "tight is tight" club as well. I guess you learn something new everyday...
KingBird
by TBYODA » Wed Apr 16, 2014 9:17 pm
This site may help your search be easier to call local dealer.
http://parts.nalleygmc.com/products/Che ... 61155.html
by HARDTRAILZ » Thu Apr 17, 2014 8:29 am
if you pull a bolt, it may be marked so you can find the grade and match it.
by rjwz28 » Thu Apr 17, 2014 7:08 pm
HARDTRAILZ wrote:
rjwz28 wrote:
TBYODA wrote: Take one of the others out (hopeful not breaking again) and go to ace hardware or other such store and match it and get a metric grade 10.9 version. I am sure you should be able to find something that will work. Most hardware stores have those thread matching boards to help size it up.
:thumleft:
rjwz28
