AA1PR’s Tire Carrier
by AA1PR » Mon Jun 08, 2015 11:38 am
Been wanting one for a while now, last year I had an eye opener where I learned with my injury (disability) I couldn’t get the spare tire down from the factory installed location
I originally thought about something like this on my rear door
so in the mean time I have been tossing around this idea
for my receiver adapter I'm using a rage power sports 8" hitch extension its class IV rated
here is my plan
I got all the parts together to get this completed yesterday, so I stopped by the local welder & again he wont weld my stuff..Oh well I’ll do it myself
so I got my own flux core welder & goodies to finish it off once warmer weather gets here. I haven’t welded in years but its like riding a bike, hopefully
Trying to enlarge holes by going up one size bit is a PITA
Got some step bits for my holes, so I get nice straight clean holes & makes life so much easier
Got it welded up & painted
Didn’t care for my original mounting idea so I changed it out, welded on another piece of 4""X8"X3/16" plate over the old piece & then re-drilled using the step bits
Added several layers of duct tape so I didn’t get any corrosion between the steel plate & the aluminum rim as oxidation usually occurs
Letting the sun bake on the paint for a while
Got it mounted & now to get the tire on
All on
I can even open the rear window
Left it on for a week like this while we were on vacation with friends
Then decided I wanted to notch the upright in order to get it to lean backwards ever so slightly
So I took about 5/16" of a notch out
Basically how it’ll look in the upright position
So after carefully grinding all the joints & welding I decided to add some plate across the welded joint just in case, better safe than sorry
& here is my finished product
About 200 miles later & it’s still doing well
1966 Stevens M416 trailer too
AA1PR
by TBYODA » Mon Jun 08, 2015 7:22 pm
Nice job! Mike
by AA1PR » Mon Jun 08, 2015 10:23 pm
TBYODA wrote:Nice job! Mike
Thanks
if you ever make it over this way we'll have to wheel together
AA1PR
by Eredin » Tue Jun 09, 2015 12:52 pm
That looks good! My original plan was to go that route but I was afraid that when wheeling, it would rock back and forth with the little amount of play in the factory receiver, making it rattle all the time.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by AA1PR » Tue Jun 09, 2015 9:46 pm
Eredin wrote:That looks good! My original plan was to go that route but I was afraid that when wheeling, it would rock back and forth with the little amount of play in the factory receiver, making it rattle all the time.
thats why I added some plate & bolted it through the bumper, maybe its not clear, hopefully this shows it a bit better
AA1PR
by beavercountyemt » Sun Jun 14, 2015 4:00 am
Awesome job. not only does it look great and work, but you got to do it yourself instead of paying someone to do it. I think it makes it that much better.
beavercountyemt
by bartonmd » Sun Jun 14, 2015 7:55 am
Looks good!
Looks like you could make it a little lower, if you wanted to? See better out the rear window, etc.
by AA1PR » Sun Jun 14, 2015 11:13 pm
by beavercountyemt » Sun Jun 14, 2015 3:00 am
bartonmd wrote:Looks good!
thanks guys
yes I should have test fit it before I made the cut
my back was killing me & I was just happy to finish her off
can still see out the back some, not great, thats what mirrors are for right :)
I might after I get some light body work done on the rig (monstaliner), cut the top angles section down some & re-weld that since I cant shorten the vertical upright since its bolted on the base & has my 3/8" bolt that goes through it so it folds down near the upright supports
I guess I ought to get a pic of it folded down, when it folds down I can open the rear door, that was another main objective with it
maybe I'll sell this one & build another over the winter now I have a better idea of what I really need
AA1PR
by v7guy » Mon Jun 15, 2015 5:38 am
Looks nice, really nice to see more guys building stuff!
