No problem Larry. I was a gamer, so used to the pics or didn't happen thing.
So I went back and took some of the ideas that were posted before and revamped the bar. I redid the guard to help deflect away from the roof. I still need to add the tubing or a support for the tabs. I will probably be looking at the tubing since with some spacing at the tab points, I could then run the wiring through that to give a nice look. I'm also going to probably add one more vertical bar on either end to help protect the outer lights, since they are a bit exposed. Here are the pics.
Corner where I will probably add another bar (on both sides).
Close up on how the light sits. There is also enough room to manipulate (if needed) the light behind the bar.
Edit: And yes, I am aware that the front support bar is not straight....
