Gordinho80 wrote:The base piece of C that remains after cutting the sides is 4'.
I do believe my C is the same thickness. It's beastly. The 10' section weighed in at over 80lbs(36kg).
Beastly! with that you may throw away that tire carrier and weld a new one
![thumleft :thumleft:](./images/smilies/icon_thumleft.gif)
I suggest you use iron of no more than 2.5 or 3mm thick for the sides of the bumper i don't think you need more than that...
you can start cutting the first "wing" like i did and welded with the angle you want... and then measure the following parts with cardboard, soldering and copy each and every one of the feet, to make the other corner.
so I did and it was easy, they are just ideas!
Juan Pablo
