Fiberglass
by OregTrailBlazin » Tue Jan 18, 2011 6:09 pm
NickNorie wrote:Another good thread right here.
http://www.dezertrangers.com/vb/fab-shop/74366.htm
So your thinking I should do it this way?
After reading that one, I would just line your fenders and spray foam onto it. Check out the other forum they dropped http://www.fiberglassforums.com/index.php
I would definitely do it like the first thread. Make a plug, then build the mold. You'll be able to build more in the future as yours break, and you have the potential make some money. And don't use styrofoam, the spray foam or the foam board have tighter cels to them and don't missform as easy. Styrofoam is basically a bunch of foam balls glued together, the foam board and spray foam is pure foam, if that makes sence. I'm sure someone remembers tearing styrofoam apart piece by piece as a kid..
Last edited by OregTrailBlazin on Tue Jan 18, 2011 6:55 pm, edited 1 time in total.
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by That1Guy » Tue Jan 18, 2011 6:27 pm
I would definitely do it like the first thread. Make a plug, then build the mold. You'll be able to build more in the future as yours break, and you have the potential make some money. And don't use styrofoam, the spray foam or the foam board have tighter cels to them and don't missform as easy. Styrofoam is basically a bunch of foam balls glued together, the foam board and spray foam is pure foam, if that makes sence. I've sure someone remembers tearing styrofoam apart piece by piece as a kid..
Definitely thought the first thread was more the way to go. Hopefully this works. Might start next monday if I find a local place with everything I need.
Previously known as NickNorie
That1Guy
DriveTrain: 2WD w/ G80
by Blackout » Tue Jan 18, 2011 7:05 pm
Maybe you can even get to producing more and having some of us buy the finished product? Great idea though. Looking forward to see it progress.
Blackout
by That1Guy » Tue Jan 18, 2011 7:08 pm
Blackout wrote:Maybe you can even get to producing more and having some of us buy the finished product? Great idea though. Looking forward to see it progress.
That is a possibility. If I like the outcome and you guys do to it is highly possible I will sell them.
That1Guy
by Rob93 » Sat Jan 22, 2011 2:16 pm
Started on some flares today, just doing the passenger front for now to see how it comes out
Rob93
by OregTrailBlazin » Mon Jan 24, 2011 2:43 pm
Rob93 wrote:Started on some flares today, just doing the passenger front for now to see how it comes out
Kinda shocked no one has said it.. :need pics:
Johnny Kurz
General Manager
541-474-2879
Our Vendor Section
OregTrailBlazin
by Rob93 » Mon Jan 24, 2011 5:12 pm
I had pics but my dad took the camera to work this week :hissyfit:
Next time I see my mom I'll grab hers and take a couple... hopefully tomorrow
Rob93
by Hpimichael02 » Mon Jan 24, 2011 5:15 pm
hmm rob i may have to swing by sometime to see these in person :)
Hpimichael02
by Rob93 » Mon Jan 24, 2011 5:22 pm
Hpimichael02 wrote:hmm rob i may have to swing by sometime to see these in person :)
Not much to see yet, I'm only working on one, trying to see what method is easiest before I do all 4. But if you're up for the drive you're welcome to check it out when its done. Maybe we can finally get a SoFla meet
Rob93
by Hpimichael02 » Mon Jan 24, 2011 5:29 pm
go on trailvoy and set one up .. im wanting to trail with yall down there , just no broken sunroofs :)
Hpimichael02
by That1Guy » Mon Jan 24, 2011 9:33 pm
Well a quick test fit of the spacers tells me fenders are unnecessary at this point
That1Guy
by Hpimichael02 » Mon Jan 24, 2011 11:45 pm
What size tire u have
Hpimichael02
by That1Guy » Tue Jan 25, 2011 12:04 am
Hpimichael02 wrote:What size tire u have
255-70-16. When I can get my hands on a 3 inch body lift I will be going up to a MINIMUM of 33's, but the goal is 34-35. When I get the bigger tires is when I will experiment with the fenders.
That1Guy
by Diacom » Tue Jan 25, 2011 10:48 am
Not extended out past the fender opening?
by That1Guy » Tue Jan 25, 2011 2:34 pm
Diacom wrote:Not extended out past the fender opening?
Ill get pictures later but nowhere near as far as I expected. In fact the tops are still covered.
That1Guy
by janesy86 » Tue Jan 25, 2011 2:39 pm
With that size tire on a stock wheel, that sounds about right. My 265/75/16's only stick out maybe 3/4-1". With spacers.
by That1Guy » Tue Jan 25, 2011 2:41 pm
janesy86 wrote:With that size tire on a stock wheel, that sounds about right. My 265/75/16's only stick out maybe 3/4-1". With spacers.
Ya and at this point fenders would just look goofy and not have a function. Therefore no point in doing them at the moment
That1Guy
