whats up yall im new here stationed in colorado
by just for fun » Sat Mar 19, 2016 1:58 am
i dont have pictures yet of my build but i put a 3" cheap block lift on the 08 tb for now. im looking at running this, could use some advice. massive adj upper/lower control arm kit, markmc 3" suspension lift, 3" body lift, 1.5" wheel spacer 6x5.0 skyjacker softride coils c24r, fox 2.0 struts in the rear... I'm currently deployed not sure if this will work. also ill be using my stock TB rims 17" what would be a good tire size with this lift?
just for fun
by SnowBlazer » Sat Mar 19, 2016 2:01 am
What's up man! I'm Ryan and I'm in Colorado Springs if you ever want to meet up and wheel.
SnowBlazer
by just for fun » Sun Mar 20, 2016 1:06 am
I'm deployed right now won't be back til winter but I'm still planning on going up old stage maybe eagle rock next year
just for fun
by SnowBlazer » Mon Mar 21, 2016 12:07 am
just for fun wrote:I'm deployed right now won't be back til winter but I'm still planning on going up old stage maybe eagle rock next year
Old Stage is closed half way through now at the lake for some reason. Maybe it'll be back open by then. Who knows with CDOT. They do close Rampart Range for the winter at Garden of the Gods as well. smh
SnowBlazer
by v7guy » Mon Mar 21, 2016 12:31 am
What gears are in it?
by just for fun » Mon Mar 21, 2016 1:57 pm
3.42 now I'm definitely looking at redoing my gears or would it be better to add another tranny cooler if I wanna push 32s
just for fun
by mason10198 » Mon Mar 21, 2016 6:24 pm
That depends on what you want to do with it and how you want it to perform. I'm currently running 32s on 3.42s with an extra trans cooler, and I have had no problems at all. However, I never tow anything and I've made terms with the power I'm losing with the crappy gear setup.
Sent from Tapatalk
by Jrgunn5150 » Mon Mar 21, 2016 7:08 pm
Welcome!
by hilljb » Mon Mar 21, 2016 11:00 pm
Howdy! I'm in Broomfield, CO.
hilljb
by just for fun » Mon Mar 21, 2016 11:25 pm
I think when I get back I'll add the tranny cooler then change my gears later
just for fun
by Jrgunn5150 » Mon Mar 21, 2016 11:52 pm
I don't think the world will end if you don't change your gear's.
by just for fun » Tue Mar 22, 2016 12:03 am
Probably not but I will see where the army takes me if there's no good offroad spots then I guess it'll end up being a mall cruiser so I won't have to worry bout the gears
just for fun
by Jrgunn5150 » Tue Mar 22, 2016 12:08 am
If need be, leave it in third for lower 50-65 mph speeds. Just don't let it shift up and down a billion times a minute.
by Anthony Hernandez » Tue Mar 22, 2016 2:59 am
Welcome. And first of all, thank you for your service. (Should've been the first thing said.... I digress) take your time and search this site brother.. It's a plethora of info...( and time is all you have.) Obviously our tbs aren't rolling around with armored "V" hulls and planetary gears.. But... These little basterds are fully capable of making great long lasting memories...that said... Choose your mission, and plan accordingly.. If end state you want to go get rediculous, then plan now and fund it..( again you only have time) don't fiddle //// with a 2" lift if your planning to keep this bitch your main supply line to life... Speaking from experience it's best to spend the money while you have it and can plan for the worst and hope for the best... All implications implied...again... Thanks for doing what less than 2% of the worthless shit bags of society will never do... Demon4-3... Out.
by v7guy » Tue Mar 22, 2016 3:14 am
You'll find it'll look a lil goofy with 32s and the body lift and suspension lift, I ran around like that for a couple years LOL
Even with a cooler you stand a decent chance of running into some issues overheating the trans going with bigger tires though. If I remember correctly Regulator had 3.42 with 35s? He ended up getting a trans heat warning on the way to badlands and we had to pull over to let it cool. Probably won't be any big deal just running around town though.
by just for fun » Tue Mar 22, 2016 3:52 am
If I were to rebuild my gears do I need everything or just the. Ring and pinyon swapped swapped to 4.10 or even 3.73
just for fun
by v7guy » Tue Mar 22, 2016 5:18 am
Some guys don't swap bearings, they just slap in the ring and pinion as long as the bearings look ok. It's usually recommended to do a rebuild though.
I think you'll find many guys would recommend you go with 4.56s as you look at 33 and up sized tires.
by just for fun » Tue Mar 22, 2016 9:06 am
I'm not trying to spend to much money I think I'll get rid of the body lift and just go with 32s also can I swap out the front did gears like I would the back
just for fun
by TBYODA » Tue Mar 22, 2016 12:45 pm
just for fun wrote:I'm not trying to spend to much money I think I'll get rid of the body lift and just go with 32s also can I swap out the front did gears like I would the back
Sure you can. Sam do you have a 5.3L or a EXT TB? Highly suggested to swap rear end (in you case since you have a 08 you need a 06+ out a EXT or SWB 5.3L) because you get the bigger 8.6" ring gear and more aftermarket locker support. Plus the bigger axle is stronger. Many members just swap to SS 9.5 axle with 4:10's.
by just for fun » Wed Mar 23, 2016 5:55 am
I just have a ls nothing special but can pull it's weight around
just for fun
