need help finding a lift for my 04 tb
by liftedblazer » Sat Feb 02, 2013 10:39 pm
i have an 04 tb ls ext and id like to get up into the powerlines without ripping my rockers off i dont want to get to high up there were im having to extend everything (steering, ignition cables ext.) but i want to have a lift thats noticeable any suggestions. im new to forums
sex is like muddin you see the hole you think about it you slowly ease into it and once you in its balls to the wall until your motor blows
liftedblazer
by DirtyBacon04 » Sun Feb 03, 2013 12:15 am
If you just do a suspension lift as opposed to a body lift, then you won't have to worry about any exension of steering. Use the search bar is the handy corner up there, and there are NUMEROUS threads about it
by liftedtbinvt » Sun Feb 03, 2013 12:42 pm
I have a 2 inch suspension lift from BDS and a 2 inch body lift from Zone I put them both in myself in my driveway and have no reall experience working on vehicles. The body lift requires relocation of bumpers and comes with a 2 inch steering exteinsion but it's not a big deal. They only problem I had with the susppension lift was compressing my front springs to change the mount. That was only because the compressors I borrowed were old and rusted out. But all together I paid around 900 bucks for 4 inch of lift still savin for tires
liftedtbinvt
by Cable810 » Sun Feb 03, 2013 4:08 pm
Marks 3" lift and some 32s and you'll be set!
by TheVoy » Mon Feb 04, 2013 10:36 am
Cable810 wrote:Marks 3" lift and some 32s and you'll be set!
This is gonna be your best bet, Its what I did and it made a huge difference. I was able to go from stock 28 Inch tires all the way up to 32.5s with no problem. :Iagree:
Click this link to see before and after : viewtopic.php?f=8&t=4030
02 Envoy SLT 4x4
3 Inch Front Lift - 2.5 Inch Rear Lift
1.5 Inch Wheel Spacers
265/70/17 (32.5in) Definity Dakota A/Ts
Eaton G80 Locker
TheVoy
by Gordinho80 » Mon Feb 04, 2013 11:22 am
A member on here is removing his suspension lift, c bausch. Might want to check if he still has it available...
by Me007gold » Mon Feb 04, 2013 4:54 pm
You also need wheel spacers to fit that much tire.
Me007gold
by Cable810 » Mon Feb 04, 2013 9:09 pm
Forgot about the spacers.....
