Northeast Ohio Newbie
by Jimz02TB » Sun Aug 26, 2012 5:45 pm
Hello everyone,
My name is Jim and I found this site through Trailvoy.com... Hoping to learn alot about Trailblazers. I just picked up my first 4x4 vehicle which is my 2002 Trailblazer LT which after looking into the RPO codes found that it has the G80. I may be new to the site but im not new to forums, i been tinkering and modding my vehicles since i started driving in 2005, Im 25 and i just got into the Truck/SUV scene and i used to be in the small GM compact car scene in which i had a Cavalier that i took to the GM tuner Bashes that they had for the J-bodies, but when i recently wrecked my Cavalier i quickly found out that i needed a 4wd and something to haul people as well as gear/equipment since for the past year i been using my cavalier for those purposes since im also a Paranormal Investigator and avid Camper and i like to fish every now and then. Anyways enough about my little history. LOL.... I got my trailblazer because i figured it would be a perfect vehicle for what i plan on doing and so far so good with it. I paid $3500 for it and it has 158k miles on it and is running real strong and i havent had a lick of trouble with it, been traveling alot with it.
My overall goal for my TB is to mod it a little at a time as well as fix the things it needs... It needs a hood, drivers fender and front bumper because it has a couple dents on it. I also eventually plan on doing some suspension mods to it as well as a little performance mods. Im hoping to learn all i can about doing the different things i plan on.
If you have any comments or criticism it is welcome, I enjoy learning and talking to others about TB's
Jimz02TB
by NC_IslandRunner » Sun Aug 26, 2012 7:20 pm
I don't remember there being a Jim on Ghostbusters.....j/k
Welcome!
by Cable810 » Sun Aug 26, 2012 9:18 pm
Welcome!!
by Cody_S » Sun Aug 26, 2012 9:30 pm
Welcome aboard :cheers:
Cody_S
by djthumper » Sun Aug 26, 2012 9:39 pm
Welcome!
by Jimz02TB » Tue Aug 28, 2012 12:49 pm
After looking over my trailblazer the other day when i went over to my Uncle's house and he has a 2003 LTZ Trailblazer and i noticed that mine is lower then his LTZ, now mine is the LT but when i went underneath mine i noticed there is drop shocks on the rear i think they are called "Drop Zero" and there is blue coil springs on mine, the front struts are Bilstein.... I like the stance of it but i dont think it fits my TB since its a 4WD. Now i do plan on going back to stock suspension with a little lift to it or going with an aftermarket lifted suspension. I dont wanna go with a huge lift on it, prolly just a couple inches or so in lift.
Jimz02TB
by Jimz02TB » Tue Aug 28, 2012 12:54 pm
Here are a couple pics of my TB...
Jimz02TB
by bartonmd » Tue Aug 28, 2012 1:02 pm
Welcome!
Is that front tire in a hole, or does it just have 18PSI in it?
by Jimz02TB » Tue Aug 28, 2012 1:12 pm
Ya mike the tire was a little low the pic was taken when i first got it, i have since aired up the tires to the correct psi.
Jimz02TB
by bartonmd » Tue Aug 28, 2012 1:14 pm
OK, good.
by navigator » Tue Aug 28, 2012 5:05 pm
I think yours has been lowered all the way around.
by djthumper » Wed Aug 29, 2012 2:19 am
navigator wrote:I think yours has been lowered all the way around.
Depending on the tires you have on there now I think that thing is lowered about 1.5" all around
by s3customs » Thu Aug 30, 2012 11:53 pm
Welcome aboard. I just seen your location, your a little over an hour from me.
s3customs
by Jimz02TB » Fri Aug 31, 2012 12:49 am
Ya it is lowered all the way around, im not sure what brand springs they are but they are blue. lol right now i gotta deal with it being lowered until i find a set of stock springs/struts or just go ahead and order them through my work.
s3customs: Im not sure where Uniontown is, is it by chance up near Akron area? cuz i work up in Kent, Ohio and i know that area fairly well.
Jimz02TB
by Jimz02TB » Fri Aug 31, 2012 12:51 am
Ya the tires on it are the stock tire size which i believe off hand is 245/70/16?
Jimz02TB
by navigator » Fri Aug 31, 2012 9:57 am
Jim, what are you planning to do? Are you planning to get back to stock height or add some lift to your TB?
If you are looking to get back to stock height you can likely source some stock springs here on the cheap. Post a WTB thread in the classifieds area.
If you want some lift, there aren't a lot of options for lift springs for our platform but there are some options. We can help guide you in the right direction.
Let us know your plans and read through the thread below to get some ideas, search and ask questions. Just make sure to search before you ask questions, we try to keep the noise down to where searches are more meaningful.
viewtopic.php?f=8&t=3060
by NC_IslandRunner » Fri Aug 31, 2012 11:20 am
Jimz02TB wrote:Ya it is lowered all the way around, im not sure what brand springs they are but they are blue. lol right now i gotta deal with it being lowered until i find a set of stock springs/struts or just go ahead and order them through my work.
If you want stock rear springs I have a set you can have just pay shipping. Struts/shocks I suggest shockwarehouse.com, You should be able to find someone with front springs here to.
by navigator » Fri Aug 31, 2012 11:39 am
I would also say that if you plan to lift, go ahead and get all your parts(springs, shocks, lift kit etc) and do it once so that you only have to get one alignment.
by NC_IslandRunner » Fri Aug 31, 2012 12:04 pm
navigator wrote:I would also say that if you plan to lift, go ahead and get all your parts(springs, shocks, lift kit etc) and do it once so that you only have to get one alignment.
:Iagree: If you want to lift don't bother going back to stock it would be a waste.
by Jimz02TB » Fri Aug 31, 2012 12:31 pm
You know i didnt think of it that way, those are actually good points, i would like to get a little higher than stock ride height. So ill prolly just go that route and gather all the components needed for a lift and just drive with what i have now until all the components are set in place. Cuz i can handle being lowered until i get everything i need.
Thanks for the input guys, Ill do some research on the different options i have available. Cuz im not looking to go ridiculous on height, just a little above stock height. Maybe something that i can use to go to Yankee Lake Truck Night up here in Northeast Ohio.
Jimz02TB
