New member in VA
by Anthony Hernandez » Mon Apr 07, 2014 11:45 pm
Welcome bro I'm from vb also...
by Trail X » Tue Apr 08, 2014 10:07 pm
TBYODA wrote:I feel sorry for Ryan for the misguided need and for the damage to his TB even in minor accident, not to mention a very weak winch point for a 5k+ SUV. :facepalm: I thought very early on getting a bush guard because I thought it would look nice on the front of my TB. However in RESEARCHING I found only the WAG mounted to the frame and did not kill the approach angle. Ryan's brand looks to be like most others that mounts to the radiator brackets, it may even have supports back to the bumper, IDK. However even if it has the brackets you will push back the radiator into the fan even in a minor accident or rip off the bull bar when trying to winch and most likely damage the radiator. :wallbash:
Actually, the WAAG mounts to the same place as countless other bull bars do, the rad supports. It just has its lower support arms run through the bumper, instead of under it, so there is less of a lever arm on the brackets, allowing the brackets to survive a frontal load only a bit better than others.
