Noob from West Virginia
by fishsticks » Fri Jun 10, 2011 1:42 pm
bgwolfpack wrote:Maybe it was the front springs this conversation was about and not the rears. The fronts are not progressive correct?
AFAIK they are not.
by djthumper » Fri Jun 10, 2011 3:50 pm
Blackout wrote:I wouldn't dismiss the Z71 springs. When I first lifted I wasn't hauling all the weight I do now in the back, but I didn't feel that it was a bad ride at all
I wasn't dismissing them. I was just letting him know since some people do not like a firm ride. I can definitely say that I like the ride a lot better with the Z71s than without with the same loads that I have hauled multiple times. I like the ride without a load as well, but I was expecting it to be more like a truck ride with the swap.
by Trail X » Mon Jun 13, 2011 4:02 pm
ruffryder59 wrote:Ok this is what I put together so far from reading and searching. I want to do this right the first time. I am going with MarkMc's New suspension lift. 88 springs up front with bilstien hd's rear z71 springs and have not decided what shocks to use in rear. I will take all input on this set up. My truck is totally stock right now. What size tires do you think I can fit with this setup on stock 17 inch wheels. I know I will need wheels spacers. Im going to wait till I get all this stuff and do it at once. Please let me know if there is any compatibility issues with any of these items or if there is going to be any trimming ect.... I read that I might want to flip upper control arms too.
88 springs plus mark's lift is going to be really high, especially without a bunch of steel up front.
I'd do the lift first, then add weight to the front... then get your springs upgraded to prevent topping out the front end.
by ruffryder59 » Wed Jun 15, 2011 4:37 pm
Thats kinda what I was thinking. I should be ok with stock shocks up front with marks new lift right? With the z71's in the rear will the factory shocks do for now as well?
ruffryder59
by bgwolfpack » Wed Jun 15, 2011 4:53 pm
Time for Rear Shocks to become a sticky?
by Trail X » Thu Jun 16, 2011 8:26 am
You should probably upgrade both sets of shocks.
Randy, what thread? Normally we will only sticky threads that have nearly all of the information well documented in the first post.
by ruffryder59 » Mon Aug 22, 2011 8:44 pm
Marks 3 inch body lift installed now quite a job by myself! I may start a build thread shortly. I have collected almost all the stuff I need for a suspension lift next. :safari:
ruffryder59
by Trail X » Mon Aug 22, 2011 9:34 pm
:need pics:
Congrats on the BL!
