[img]
[imhttp://i1133.photob
[img]
you can use either pully stock or ext, both press on psc pump.
pressing on pully(went with stock for now)
pump mounted up
made a bracket to hold res, and it bolts to fender well and filter box bolt.]
res is above pump and out of the way of oil and trans dip sticks.
ps fluid cooler.
mounted under rad guard. kept the stock cooler.(ran new one after then returns to res)
drilled out holes in rad guard for air flow.
1.75 redneck ram and hoses welded to axle and tie rod.
gear box and were hoses are tapped in.
also ran a whole new high pressure hose to in of gear box
filter from res
back of pump
