2004 Chevy Trailblazer LT
Engine/Drivetrain:
Original:
4.2L I6
Selectable 4WD
3.73 Gears
8" Open Rear Diff
Modifications:
5.3 Swapped (Freshly Rebuilt)
Comps Cam Kit
Ported Heads
K&N Intake System
High Flow Cats
Electric Cut Out
OE Muffler
SS Braided Fuel AN Lines 8AN Supply 6AN Return
SS Braided Transmission Lines 6AN
26,000 GVW 6AN Transmission Cooler (10"x20")
4.56 Gears
Powertrax LockRight (Front)
Front & Rear Diffs Rebuilt
Rebuilt Disconnect
8.6" Rear Axle Swap G80
2" Longer Drive Shaft With Thicker Tube
5.3 Front Drive Shaft
1.5 Inch 6x5.5 Adaptors
Suspension:
GM 89 Springs
Bilstein HD Gas Shocks
Reversed Upper Control Arms
BDS Rear Shocks
Z71 Rear Springs
Front Sway Bar Removed
Rear Sway Bar Removed
3" Lift Kit
3" Body Lift
HD Tie Rod Swap
Exterior Modifications:
Cut Front Fenders
Cut fender wells Then Removed
17x9 Gear Recoil Rims
295/70/17 Nitto Trail Grapplers MT
Nathan AirChime K5LA Train Horn
Interior Modifications:
HK USP .45
20% Tint All The Way Around
20+ gallon Air Tank
25' 3/8 Air Hose
50' 1/2 Air Hose
Air Tools
Recovery & Safety Equipment:
Whelen HHS2200 Hand Held Programmable Siren
Whelen SA315P Projector Series Speaker
Whelen Vertex Super-LED Hide-A-Way Light (6)
18,000lb Tow Strap
18,000lb Bull Rope
Electrical Modifications:
SST Viper Alarm System With Remote Train Horn Honking Up To 1 Mile
JL Audio Sound System
Air Zenith Dual OB2 Air Compressor (2)
HornBlasters 165-200 Pressure Switch w/ Dual Relays
HID Off Road Lights (2 Sets)
Hid High & Low (2 Sets)
Future Modifications:
Steel Front Bumper
Steel Rear Bumper
Skid Plates
Rock Sliders
Rear Air Locker (Replace G80)
12,000 LB Winch
Interior Rear Amber Warning Lights
