CV half shaft won't remove from wheel bearing
by drburke » Sun May 26, 2013 4:56 pm
Any tips on what to do? It came out of the 4WD disconnect fine, but it's seriously jammed up in the bearing and no amount of work I've done has gotten it off yet.
drburke
by NC_IslandRunner » Sun May 26, 2013 5:11 pm
big hammer! lucky the cv shaft sticks way out and gives a nice target!
by drburke » Sun May 26, 2013 5:18 pm
I couldn't figure out how hitting it would work-- then I stopped thinking and started doing.
Thanks!
drburke
by NC_IslandRunner » Sun May 26, 2013 7:26 pm
Each side of my truck is on its 3rd cv axle so I've had pratice!
Last edited by NC_IslandRunner on Sun May 26, 2013 7:28 pm, edited 1 time in total.
Each side of my truck is on its 3rd cv axle so I've had practice!
by DirtyBacon04 » Sun May 26, 2013 8:03 pm
would coating them with anti-seize help at all?
by TangoBravo » Sun May 26, 2013 8:22 pm
DirtyBacon04 wrote:would coating them with anti-seize help at all?
That's what I usually do, I only put it on the splines not the threads. It seems to help me, I usually have no trouble at all gettin those to let loose.
TangoBravo
by Opeth » Sun May 26, 2013 8:24 pm
Ive never had to coat a cv shaft splines in anti- seize. A BFH has always freed it up out of the hub bearings, and I live in the rust belt. Wouldn't hurt anything to do it, but I don't see it necessary.
by TangoBravo » Sun May 26, 2013 9:37 pm
Opeth wrote:Ive never had to coat a cv shaft splines in anti- seize. A BFH has always freed it up out of the hub bearings, and I live in the rust belt. Wouldn't hurt anything to do it, but I don't see it necessary.
I have never HAD to, before I coated the splines two whacks from a good size hammer always got it done. I decided to try anti sieze and it is so much easier that now I just use it.
TangoBravo
by navigator » Tue May 28, 2013 9:30 am
for future note, just make sure you leave the nut on a few threads(if the axle is good) before you whack it.
