Eaton Truetrac for 8" rear
by Heavyblaze » Sat May 29, 2010 11:53 pm
Has anybody seen the Eaton has a Truetrac differential out now for the 8" rears it was on www.ringpinion.com.
Heavyblaze
by The Roadie » Sun May 30, 2010 1:14 am
Saw your post on the OS and (regrettably) answered there first. You found somehting new, all right. But I discovered ARB is shipping a FRONT locker that should fit us. I started a new thread here for that.
by fishsticks » Sun May 30, 2010 2:40 pm
Bill left us 8.0'ers behind a while back anyways. :poke:
Interestingly enough, when I was sourcing parts to fix my G80... I discovered the 8.0 and 8.6 share many common parts carrier-wise. I was too focused on fixing what I have to really investigate though.
There's also an 8.5/8.6 28 spline carrier out there...
by The Roadie » Sun May 30, 2010 3:17 pm
fishsticks wrote:Bill left us 8.0'ers behind a while back anyways. :poke:
I was just copying AlekG, who outsmarted and outspent me by a good factor.
Gee, I don't see the purpose for that one. What vehicle does it go in? (To save some folks a bit of Googling, the 8.0" axles have 28 splines - the 8.6" are stronger 30 splines. Everybody should have this memorized.)
by fishsticks » Sun May 30, 2010 10:03 pm
The Roadie wrote:Gee, I don't see the purpose for that one. What vehicle does it go in?
This I do not know... What I DO know is that there's a Detroit Locker, a TrueTrak, an ARB, and all the other usual aftermarket goodies available for it.
I'd run 28 spline axles if it meant I could upgrade my locker on the cheap. Hell, my '95 Camaro is still on it's original 7.625" 28 spline axle rear. That's after a lot of strip passes on warmed up drag radials too.
by dmitry » Tue Dec 09, 2014 4:03 am
Hi,
I just bought a Truetrac for my 8.0 rear axle and now trying to figure what diff oil will work best for me. Yes I know that Eaton recommends "A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil" but looking for example at Mobil Mobilube HD plus 80w90 specs I see that it stops being a liquid at -27C. I found no related info on Russian forums (truetracs are very rare here) so I guess i'm looking for experience of people using Truetracs in northern parts of Canada and Alaska.
Thanks!
dmitry
by N7RMK » Wed Dec 10, 2014 10:03 pm
$500 seem like an awful lot to spend for a Limited slip rear end that will only perform marginally better then an open diff. a better investment is in the 8.6 and a selectable locker.
just my $.02
N7RMK
by Trail X » Wed Dec 10, 2014 10:24 pm
I don't know that we have a good knowledge base here for that. I would stop by "Bob Is The Oil Guy" to see if their forums have any related information. They tend to have the most oil related knowledge that I've found.
by dmitry » Thu Dec 11, 2014 12:44 am
N7RMK wrote:$500 seem like an awful lot to spend for a Limited slip rear end that will only perform marginally better then an open diff. a better investment is in the 8.6 and a selectable locker.
just my $.02
$680 including carrier bearings, shims and shipping :facepalm:
This car is my daily driver and the idea was to find a replacement for my blown up G80 diff that would work best on slippery bumpy roads covered with snow and solid ice. That is where limited slip Torsen-like diffs seem to perform better than selectable lockers. Unfortunately 8.6 is impossible to find here.
Trail X wrote:I don't know that we have a good knowledge base here for that. I would stop by "Bob Is The Oil Guy" to see if their forums have any related information. They tend to have the most oil related knowledge that I've found.
Thanks, I will check it, also emailed Eaton - will see what they reply (if anything:)).
dmitry
by Eredin » Thu Dec 11, 2014 11:33 am
It's not ideal, but you might find a OEM replacement on EBay, but it's hit or miss. I can't imagine you have an abundance of GMT360 parts available. Still awesome to see someone from Russia reppin!
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by lifted voy » Sun Mar 22, 2015 4:16 pm
I know this is an older thread but I live in interior Alaska and we routinely see -50 degrees and most people up here run regular gear oil with no problems. Even guys with upgraded diffs just use mobil 1 synthetic gear oil.
lifted voy
