4Crawlin Build Thread
by dirty anton » Mon Apr 04, 2011 10:48 pm
so......why wont those fit! no really nice work, stoppin by to check on progress.
dirty anton
by NC_IslandRunner » Mon Apr 04, 2011 11:02 pm
chevycrew wrote:Here is what Im up against:
When you get done are you gonna hook us up with dicount tickets to MONSTER JAM to come watch you? :poke:
Looking good :thumright:
by rjpoog1989 » Mon Apr 04, 2011 11:06 pm
I hope I'm not stating the obvious in saying "Those are huge.
Ryan
Rule #76: "No excuses, play like a champion"
rjpoog1989
by fishsticks » Mon Apr 04, 2011 11:34 pm
rjpoog1989 wrote:I hope I'm not stating the obvious in saying "Those are awesome.
Fixed.
by HARDTRAILZ » Mon Apr 04, 2011 11:37 pm
rjpoog1989 wrote:I hope I'm not stating the obvious in saying "Those are huge.
Depends on who you run around and wheel with.
by rjpoog1989 » Tue Apr 05, 2011 12:11 am
Most people I go with have 32's or 34's, but I was saying that from a Trailblazer standpoint.
Edit: The first post was also sarcasm...
Ryan
rjpoog1989
by navigator » Tue Apr 05, 2011 10:23 am
this is going to be an awesome build
I know you have to build what you got but I'm just curious if this would have been an easier if it had been a 2WD?
by chevycrew » Tue Apr 05, 2011 10:52 am
Not really, trans would need converted to 4x4, and that's really about it, so its about the same. Also there aren't any 2wds around here.
by DmccartneyFF2TB » Tue Apr 05, 2011 8:27 pm
Did you have to extend the steering shaft for the body lift?
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by HARDTRAILZ » Tue Apr 05, 2011 8:43 pm
DmccartneyFF2TB wrote:Did you have to extend the steering shaft for the body lift?
He previously stated with the built in slip he felt ok with adding the inch of lift.
by DmccartneyFF2TB » Tue Apr 05, 2011 9:09 pm
I apologize I over read that.
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by djthumper » Tue Apr 05, 2011 10:08 pm
And to think Kyle is the one that is suppose to be lacking sleep right now. :poke:
by chevycrew » Wed Apr 06, 2011 1:44 am
That pesky oil pan....
Looks like there is going to be some custom work on that big thing. About the only way to clear it, is run about 14" of suspension lift. Thats just too tall.
At least with the axle Im running, the diff itself will be offset enough to the drivers side to clear. Now I just have the issue of axle tube to drain plug. (Im pushing the axle forward 4-6")
On a positive note, it looks like there will be about 1/4" clearance between the dual cases and the fuel tank when complete.
And I got my 231 all torn down for the cut and welding of the block-off plate.
Im hoping to get the doubler in this weekend?
by bartonmd » Wed Apr 06, 2011 7:50 am
You mean 1/4" at full torque, or 1/4" static?
by chevycrew » Wed Apr 06, 2011 8:54 am
bartonmd wrote:You mean 1/4" at full torque, or 1/4" static?
Either, thats from the back of the 2nd case to the front of the fuel tank. If the motor is moving forward and back 1/4" I have problems.
by bartonmd » Wed Apr 06, 2011 9:00 am
Oh, I thought you were saying left to right...
by chevycrew » Wed Apr 06, 2011 10:49 am
Yep, that's why I took the time to clarify.
But ill know more once it gets installed.
by The Roadie » Wed Apr 06, 2011 11:19 am
Somebody on the Other Site was offering a group buy on oil pans for folks using the 4.2 engine in other vehicles. With the drain at the other side. That (or a custom oil pan) might solve your problem.
by HARDTRAILZ » Wed Apr 06, 2011 11:34 am
I shared the link to this when he first came aboard with serious intentions.
The Roadie wrote:Somebody on the Other Site was offering a group buy on oil pans for folks using the 4.2 engine in other vehicles. With the drain at the other side. That (or a custom oil pan) might solve your problem.
by HARDTRAILZ » Wed Apr 06, 2011 11:35 am
Fyi..if it helps cost I may be willing to pony up for an oil pan since I will definitely need one someday...soon I hope.
