Slideshow pics!?
by HARDTRAILZ » Fri Nov 04, 2011 8:56 pm
JamesDowning wrote:Done.
Thank you sir
by yalchga » Sat Nov 05, 2011 10:51 pm
hope the size is right if not sorry
yalchga
yalchga
by yalchga » Sat Nov 05, 2011 11:01 pm
it shouldnt be so hard to change size in CS5 ugh
yalchga
by djthumper » Sun Nov 06, 2011 3:57 pm
yalchga wrote:hope the size is right if not sorry
The new slide show is running smaller pics. The new photo size requirement is 260 x 195 pixels. If you are having problems getting the correct size let me know.
by The Roadie » Sun Nov 06, 2011 5:09 pm
djthumper wrote:...If you are having problems getting the correct size ...
...obtain the free IrfanView program, play with the Batch Conversion/Rename tool and you'll know how to fish forever. :D
by djthumper » Sun Nov 06, 2011 6:55 pm
LOL that was going to be the next step...
by steveroche » Mon Nov 07, 2011 4:02 pm
Here is another one that I like if you feel like putting up a second one of my truck.
double rock.jpg (22.86 KiB) Viewed 23255 times
steveroche
by Gordinho80 » Mon Nov 07, 2011 5:06 pm
Done
by steveroche » Mon Nov 07, 2011 5:08 pm
Thanks, I Appreciate it.
steveroche
by HARDTRAILZ » Mon Nov 07, 2011 5:49 pm
by Trail X » Mon Nov 07, 2011 5:55 pm
We're only putting up two per member, so with every additional one you add here, it will knock off one of yours. So choose which two you want Kyle.
by HARDTRAILZ » Mon Nov 07, 2011 6:07 pm
Cool. Good way to work it. I will let it stay as is for now.
by Trail X » Mon Nov 07, 2011 7:01 pm
I do appreciate the submittals though. Not sure why we don't get more.
by Regulator1175 » Mon Nov 07, 2011 9:16 pm
I am thinking the first and third pictures, but was still undecided between the first and second. I will leave it up to who ever loads them.
by yalchga » Tue Nov 08, 2011 3:36 pm
resized
feel like im doing it wrong and losing a ton of quality when i resize
yalchga
by Trail X » Tue Nov 08, 2011 5:10 pm
Gabe, you'll need to crop a bit to get back to a standard aspect ratio - the pic above was 260x174. Also, the border won't look right.
Here's an edit of your larger original:
by djthumper » Tue Nov 08, 2011 5:39 pm
Regulator1175 wrote:Image
Matt
I would like to use the second and third but the aspect ratio is off. The one in the trees is 260 X 173 and the other one is 260 x 184.
by yalchga » Tue Nov 08, 2011 6:02 pm
thanks for the tip
yalchga
by Regulator1175 » Tue Nov 08, 2011 8:30 pm
Matt
Sorry, I took that as being the maximum allowed size, not an exact needed size. Here you go, these should be better.
by djthumper » Tue Nov 08, 2011 8:49 pm
Regulator1175 wrote:Sorry, I took that as being the maximum allowed size, not an exact needed size. Here you go, these should be better.
Me too but we want them to look the best they can in the slideshow so if we can keep them all looking the same it helps.
They should show up in the rotation now.
