offroadTB.com • View topic - PLANNING: TECORE X. T10; May 2nd - May 4th. GWNF Va.
by Moots1288 » Wed Jan 29, 2014 2:22 pm
You would get more leverage with a bigger adjustable. Channel lock makes a adjustable with a large mouth opening.
by Moots1288 » Wed Jan 29, 2014 2:55 pm
Just use a 2ft
Image no problems then
by Trail X » Wed Jan 29, 2014 3:13 pm
I thought you were worried about having enough room Matt.
by Moots1288 » Wed Jan 29, 2014 3:14 pm
by ErikSS » Wed Jan 29, 2014 3:22 pm
If you go as small as a 12" pipe wrench you will probably want a cheater pipe. If you have then tight they require a pretty good pull to break loose. Since it is machined for a 2" wrench I can't imagine a pipe wrench wont grab it. The only time I worry is when the slot for the wrench is machined in a way the pipe wrench can't get to the hex.
Mike I bent a cheap Chinese TRE that I threw on before I knew better. Not a sleeved Moog.
by Regulator1175 » Thu Jan 30, 2014 12:50 am
by Moots1288 » Thu Jan 30, 2014 12:53 am
by Wahugg » Thu Jan 30, 2014 5:03 pm
I am not sure if this appropriate but...
If someone has a SWR tuner for a CB, would you be willing to bring it so I could tune my CB properly?
And if this is inappropriate, are there any common places to go that would have a tuner to rent for a nominal fee?
-Wahugg
Wahugg
by TBYODA » Thu Jan 30, 2014 5:09 pm
by Moots1288 » Thu Jan 30, 2014 5:36 pm
by dvanbramer88 » Thu Jan 30, 2014 5:42 pm
by Wahugg » Thu Jan 30, 2014 5:46 pm
Wow! The cheapest I could find was roughly 40 dollars shipped! I must have been looking in the wrong spots!
Moot's; if your willing to then that would be appreciated, but otherwise i don't mind the ~$17 dollars to pick one up.
-Wahugg
Wahugg
by mikekey » Thu Jan 30, 2014 5:46 pm
mine is too, I'll have it with me. I think mine might need retuned. We could probably all tune ours up if needed in the Walmart parking lot.
by ErikSS » Thu Jan 30, 2014 5:48 pm
by dvanbramer88 » Thu Jan 30, 2014 6:07 pm
by Moots1288 » Thu Jan 30, 2014 6:08 pm
Why you got to tell everyone about my Lot Lizard experience :wallbash:
:D
by TBYODA » Thu Jan 30, 2014 6:21 pm
by Moots1288 » Thu Jan 30, 2014 6:23 pm
by TSAdventurez » Thu Jan 30, 2014 6:24 pm
@TSAdventurez
Formally Known as TrailShaman
TSAdventurez
by Moots1288 » Thu Jan 30, 2014 6:31 pm
Return to Eastern U.S.
