offroadTB.com • View topic - Radflo Custom OEM replacement Coilovers
Products offered by our vendor: OregTrailBlazin
Moderator: OregTrailBlazin
by fishsticks » Mon May 21, 2012 11:10 pm
Oooooooooooo...
Ahhhhhhhhhhhhhhhhhhhhh!
8-)
The old Trailblazer -
by djthumper » Tue May 22, 2012 12:31 am
Is it tomorrow already?! :D
by JCrayton99 » Tue May 22, 2012 1:47 am
So what is the range of lift available with there? Stock to 2"?
Sent from my DROID RAZR using Tapatalk 2
JCrayton99
Rank: Offroad Guide
by bartonmd » Tue May 22, 2012 6:32 am
by bartonmd » Tue May 22, 2012 6:34 am
by bartonmd » Tue May 22, 2012 8:15 am
The only update to the ride, after the drive to work this morning, is that since there is no rubber in the upper mount, like stock, you can feel every single joint, crack, crevis, or flea on the road. However, I suspect that people with the BDS or Mark's new lift are already feeling some version of this. Mine is likely worse because of the 10-ply 245 tires I'm running at 45PSI, so I don't have the larger tire at lower pressure to take a lot of that away, that you do...
This is also without the winch on, so we'll see how that is, tomorrow...
Having said that, it still doesn't ride much harsher than the Cruze. Maybe the joints are a little harder, but it's not bad, really...
Also, the handling is -WOW- because of the stiffer front springs.
by bartonmd » Tue May 22, 2012 10:31 am
As an aside, from before, the 88's are 74 n/mm, and these springs are 105 n/mm
by Trail X » Tue May 22, 2012 1:13 pm
Looks great! Is the shock body threaded? Hard to tell. If so, its nice that you can dial in any lift that you may wish for. Do they have to be disassembled to change the height?
by bartonmd » Tue May 22, 2012 1:52 pm
Yeah, the body is threaded. I haven't specifically asked, but any of these other type dampers I've used, you just unlock the collar, then yeah, dial in any lift you want (though it would help to have the weight off the wheels when doing so).
by OregTrailBlazin » Tue May 22, 2012 5:58 pm
Johnny Kurz
General Manager
541-474-2879
OregTrailBlazin
by bartonmd » Tue May 22, 2012 8:35 pm
by navigator » Tue May 22, 2012 10:13 pm
come on Mike, we need full side profile pictures of your TB with the new Coilovers!
by fishsticks » Wed May 23, 2012 12:55 am
by bartonmd » Wed May 23, 2012 6:43 am
by bartonmd » Thu May 24, 2012 8:31 am
With the winch on the front, it feels a lot like the rear does when I go over bumps, which is what I ordered the spring rate for (also, for the 40# of tube that's about to be added onto my bumper, when I get a free minute)... Tires are still 45PSI 10-ply goodness, but it's not any worse than the rear... Going with some larger Duratracs or something similar later this summer, so we'll see how different it is...
by bartonmd » Tue May 29, 2012 9:54 pm
Lifted the front and rear another 1", tonight... Took 1.5 hours to do the whole thing, start to finish, and the tires didn't even have to come off. With the winch, the front is 35-5/8" fender-to-ground, which means 36" without the winch.
I'll take a better pic tomorrow, but:
by bartonmd » Wed May 30, 2012 7:57 am
Better picture:
by HARDTRAILZ » Wed May 30, 2012 8:12 am
Ride stay the same?
by bartonmd » Wed May 30, 2012 8:42 am
by bartonmd » Mon Jun 04, 2012 11:22 am
Before Matt's "issue" at Badlands yesterday, I did run the crap out of these for a little bit, and they held up great! There are some woops that are more spread out than the ones on an MX track, but still pretty close together, and are 8-18" deep. I went over a bunch of them, got a bunch of air (visible to the guys behind me), and did the topped out - bottomed out - topped out - etc. etc. thing a bunch , and everything still looks good, as far as I can tell...
Return to Wheeler's Off-Road Inc
