offroadTB.com • View topic - Issues with braking
Issues with braking
by bearcat90 » Fri Jun 03, 2016 12:53 pm
Ever since I had my lift and suspension put on I've had issues with braking around turns, but today it got way worse after a trip to the shop for an oil change and tire rotation. It seems like the brakes aren't engaging and there's a grinding sound, then my Stabilitrak activates. Kind of like when you try to stop on ice or snow. But it only happens when the wheel is turned in either direction, driving straight I don't notice any problem at all. While I was at the shop, I asked them to check the brake pads as well but they didn't report anything as needing to be replaced. Any idea what the problem might be?
I'm supposed to leave for a road trip to Florida tomorrow and I'm pulling a small 8' trailer with me too so of course I'd be having brake issues now :facepalm:
bearcat90
by escapepilot » Fri Jun 03, 2016 1:56 pm
Could the grinding sound be the ABS activating? Does this happen at speed or only when very slow?
escapepilot
by bearcat90 » Fri Jun 03, 2016 2:19 pm
bearcat90
by PROSPHOTO » Fri Jun 03, 2016 3:13 pm
I've been having the same issue (started a thread yesterday about it). Appears to be normal stabilitrac Activation due to the larger tire diameter and greater difference in speed around corners. My solution is disabling stabilitrac in dry weather... Hold the traction control button in for 5+ seconds.
-Mike
PROSPHOTO
by bearcat90 » Fri Jun 03, 2016 3:16 pm
bearcat90
by TBYODA » Fri Jun 03, 2016 5:52 pm
Check the sensors on the hubs and there connection. I got a 08 and 32" mud tires's and haven't had any issues as either of you describe but I also don't take corners like I am in a race too. :lol: Also are your tire's evenly worn front the back and side to side?
by PROSPHOTO » Fri Jun 03, 2016 7:59 pm
-Mike
PROSPHOTO
by BC backroader » Sat Jun 04, 2016 9:01 pm
Sounds like it could be a bad front hub. The grinding noise may be the bearings, under side stress while turning, and that could cause the anti-lock system to do strange things. Check both front hubs for noise/play while the front is jacked up.
