For those of us that tow...
by Ole Blue » Sat Apr 26, 2014 5:44 pm
A friend of mines recently just ordered some shocks for his Sliverado, he got the extra load adjusting ones from Monroe. I looked at them and seems as of they would be long enough for our rear ends for those ring stocks springs and the 2" spacers. What do you guys think. I'm just. It sure if coil over would hit the pa bar or springs them selfs.
The part number is 58636ST
I looked up the spec
http://www.monroe.com/assets/downloads/ ... hSheet.pdf
Being badass ain't cheap, being cheap ain't badass
Ole Blue
by mikekey » Sat Apr 26, 2014 6:33 pm
What's it say in your signature there? ...
by Ole Blue » Sat Apr 26, 2014 6:46 pm
mikekey wrote:What's it say in your signature there? ...
How am I being cheap exactly?
Ole Blue
by bartonmd » Sat Apr 26, 2014 8:52 pm
If you want extra load capacity when you need it, most of us use the Airlift 1000 airbags inside the coils.
by Ole Blue » Sat Apr 26, 2014 9:04 pm
bartonmd wrote:If you want extra load capacity when you need it, most of us use the Airlift 1000 airbags inside the coils.
I was thinking about trying that but at the same time I just wanted some of you guys input. I wasn't trying to come off as me trying to find a cheap or stupid alternative to airbags. I've just always kind of been against using them.
Ole Blue
by boog2006 » Sat Apr 26, 2014 9:36 pm
I thought someone in here was already running something like that. Can't remember who
Boog2006 Build Thread
boog2006
by The Roadie » Sat Apr 26, 2014 11:09 pm
Our spring perches are designed to take additional force. Shock mounts not so much.
by JCrayton99 » Thu May 01, 2014 10:21 pm
What are the thoughts on the air bags in the skyjacker lift springs? Run the same bag? Or should there be a taller one I should look for.
Sent from my SCH-I545 using Tapatalk
JCrayton99
Rank: Offroad Guide
by The Roadie » Thu May 01, 2014 11:20 pm
If I upgraded to the skyjackers I'd have to answer this question. But I don't have the need, so somebody else will have to. Airlift engineers will give us the part number if we give them the dimensions of an installed spring at rest height.
