Quick question folks.
by tarsh » Sat Feb 22, 2014 5:39 pm
I was thinking about pulling the evaporation canister out. Would it throw codes ? Run funny? I need to replace the cross member back there. I guess what I'm really asking is can I run without it?
Take the path less traveled
tarsh
Name: Nathan Schroeder
by Moots1288 » Sat Feb 22, 2014 5:58 pm
tarsh wrote:I was thinking about pulling the evaporation canister out. Would it throw codes ? Run funny? I need to replace the cross member back there. I guess what I'm really asking is can I run without it?
You will throw a code, it should not run any different then it does with the Evap canister.
by tarsh » Sat Feb 22, 2014 6:03 pm
Cool. When I wrecked it while back it bent the back frame and tweaked that cross member bad. The one running at a 45 that holds up that canister
tarsh
by v7guy » Sat Feb 22, 2014 7:39 pm
you'll also smell fuel, if it's garaged the garage will smell of fuel. It'll be roughly like the old cars.
why not just fix it?
by The Roadie » Sat Feb 22, 2014 8:00 pm
It's an EPA required item. Surely you're not saying it's too expensive to fix up right. :coffee:
by mikekey » Sat Feb 22, 2014 8:36 pm
Planet murderer.
by navigator » Sat Feb 22, 2014 10:19 pm
depending on your state, you might not pass your state inspection.
Mine failed here in NC because of that.
by DustinC1989 » Sat Feb 22, 2014 10:42 pm
If you could see half the cars on the road in Michigan, it would be obvious they don't inspect vehicles lol
DustinC1989
by The Roadie » Sun Feb 23, 2014 9:26 am
So Michigan is off my list of "States I admire". :-)
by Trail X » Sun Feb 23, 2014 11:55 am
You'd probably also get a fuel cap loose dummy light because I believe that is all based on holding pressure in the fuel tank. If its working ok now, why not just put it back once you replace your frame?
by DustinC1989 » Mon Feb 24, 2014 3:46 pm
The Roadie wrote:So Michigan is off my list of "States I admire". :-)
Almost 25 years here, was never on my "States I admire" list. But there are few pluses
There is no emissions test, vehicle inspections, nothing... if you can afford a $75-$150 sticker for it every year you can drive it.
Camper "conversion" van I used see every summer driving around was literally an old ford van with everything behind the front seats cut off and a pick up bed camper ratchet strapped to the frame. Plus the required duct tape for sealing purposes
We are basically a cold, northern, Florida. :poke:
On topic: It may throw a code, but that's about it. If you don't like the light buy or find someone with HPTuner software
DustinC1989
by hardtimessuck » Mon Feb 24, 2014 6:14 pm
hi im jason and new to this and i have been searching around online alot i am building a 2000 chevy blazer 2wd into a 4wd using ford running gear i cam across what looked to be a home made rock box using 4-8-11
Doubler assembled:
27 spline 5 bolt 231c, with a 32 spline 6 bolt 241c.
4x4machine Box 4 Rocks doubler, JB Conversions SYE kit.
and i am wondering what parts it took to complete this unit i have a stock np 231c to start with i need some help guys thanks for reading any help is appreciated.
hardtimessuck
by bgwolfpack » Mon Feb 24, 2014 6:22 pm
I would direct you to Pirate4x4.com.
This site does not support your platform.
by Cable810 » Mon Feb 24, 2014 11:07 pm
I'd rather pay that $75-$150(I actually pay $120) than have to go through those emissions test and vehicle inspection.
by navigator » Tue Feb 25, 2014 9:10 am
Cable810 wrote:I'd rather pay that $75-$150(I actually pay $120) than have to go through those emissions test and vehicle inspection.
they ding us about $15 for a safety inspection (brakes, lights, tires, tie rods, ball joints etc) and about $15 more for an emissions inspection. Vehicles older than 1996 only get a safety inspection. One exception to that is "fuel cell" vehicles do not need emission checks, only safety checks. For some reason my suburban that is Flex Fuel/E85 is a "fuel cell" vehicle and didn't need an emissions check.
I'd rather pay the $30 and know that "most" of the cars on the road have had a safety check in the last year when my family meets them head on.
by Cable810 » Tue Feb 25, 2014 10:58 am
I figured the inspections were just cheaper, they just seem like a waist of time IMHO
by Shdwdrgn » Tue Feb 25, 2014 3:27 pm
hardtimessuck wrote:hi im jason and new to this and i have been searching around online alot i am building a 2000 chevy blazer 2wd into a 4wd using ford running gear i cam across what looked to be a home made rock box using 4-8-11
Doubler assembled:
Seriously why would you even try this? You can pick up a 4WD Blazer for around $2000. You certainly can't do the conversion for cheaper than that!
Shdwdrgn
Contributing Author
by dvanbramer88 » Tue Feb 25, 2014 4:44 pm
Doubler assembled:
Maybe its part of a solid axle swap. If you already own the 2wd truck, you're not paying taxes on another vehicle. And if anything, a 2WD truck has less stuff up front to cut off for the swap.
