Swapping 06 leather seats
by Moots1288 » Wed Feb 12, 2014 12:04 am
I just picked up a 02 LS Trailblazer and it has cloth seats. Im pondering if I can swap in 06 heated leather seats.. Is the plug like already there already? Or do I have to do some wiring of some sort? Did the bolt pattern change between early years and late model years for the seats? Does anyone have a diagram? And the buttons, do I have to cut the panel and install another button?
by Diacom » Wed Feb 12, 2014 12:24 am
One thing you'll find different between the two, the older seats have airbags built in, the newer, and I'm not sure what year they changed, but they are in the B-pillar instead.
Something to keep in mind if you value your side impact safety.
by Moots1288 » Wed Feb 12, 2014 12:31 am
But if I'm not warm I am not safe.
by TBYODA » Wed Feb 12, 2014 1:11 am
Moots1288 wrote:But if I'm not warm I am not safe.
Pansy!
by KE7WOX » Wed Feb 12, 2014 1:31 am
Diacom wrote:One thing you'll find different between the two, the older seats have airbags built in, the newer, and I'm not sure what year they changed, but they are in the B-pillar instead.
Were side airbags standard on all trim levels? My 04 LT with leather seats has the seat mounted airbags, but I'm pretty sure I've seen photos of cloth seats with a dummy cover where mine has the airbags.
I believe the seat design was slightly different for 05, so maybe that's when they changed, I guess this is a good question for those with 05s or 06s.
by Hillbillybonez » Wed Feb 12, 2014 6:35 am
I made this swap in my 03' love those heated seats been -6 around here for a few days lol
Hillbillybonez
by Conner299 » Wed Feb 12, 2014 10:37 am
My 05 has cloth seats, and no side air bags, and nothing in the pillars.
Conner299
by The Roadie » Wed Feb 12, 2014 1:36 pm
You have to hack the wiring, and you'll have switches.
by Gordinho80 » Wed Feb 12, 2014 3:20 pm
When I put power seats from an 02 in my 04 non power, I had to run wiring to power the seats. Seeing as how the heated seats have switches, I'd suspect you have to run wiring for them to work properly. Should be relatively easy, though.
by TBYODA » Wed Feb 12, 2014 4:12 pm
by RyansTBLS » Wed Feb 12, 2014 5:39 pm
My '06 has cloth seats and no side air bags. If your passenger seat is motorized, it might have something part of the wire harness, which I don't have mine. Don't you have an '06 envoy though?
RyansTBLS
by TBYODA » Wed Feb 12, 2014 7:10 pm
Matt why not get yourself a pair of these? Wouldn't it not be easier and cheaper than the whole seat? Image
by Moots1288 » Wed Feb 12, 2014 7:27 pm
TBYODA wrote:Matt why not get yourself a pair of these? Wouldn't it not be easier and cheaper than the whole seat? Image
No way, Ill just get some bum warmers
by Moots1288 » Wed Feb 12, 2014 7:29 pm
And id need leather!!
by Diacom » Wed Feb 12, 2014 10:50 pm
All I can tell you for certain as far as airbags, both of my cloth 03's have them in the seat side, and the 06 they are in the pillar and is cloth also. May be a trim package deal but I doubt it. There'd be more research to do to be sure, but I know they made a change in the seats around 04, 05 or 06.
by dvanbramer88 » Wed Feb 12, 2014 10:56 pm
by DustinC1989 » Wed Feb 12, 2014 11:09 pm
02 seats are a direct swap to a 06.
but in order to put 06 seats in a 02, you have to buy drilled and slotted brake lines, synthetic blinker fluid and add a second transfer case to the rear axle that has to be converted to a dually with 8.51 gearing
DustinC1989
by Moots1288 » Wed Feb 12, 2014 11:14 pm
DustinC1989 wrote:02 seats are a direct swap to a 06.
Does it have to be exact on the gearing? Rightnow I have 7.51 and I think the seats might fit.
by DustinC1989 » Wed Feb 12, 2014 11:27 pm
You can use the 7.51, but only if you have 24" rockstars with electrical tape for tires
DustinC1989
by Diacom » Thu Feb 13, 2014 10:34 pm
From what I can find, they changed the seats in 06. Prior to, the airbag is in the panel on the side of the seat, 06 and on they removed the airbag from the seat and placed it in the pillar.
While this is a direct bolt in as far as from the 06 to your vehicle, you will lose side airbag function and your airbag light will come on. It is up to you whether or not you inform your insurance company of the loss of side airbag. The light can likely be tricked into going out with the proper wiring as you'll have to change some for the heating anyways.
It's fully up to you on how you work it, but we've had enough people wreck their 360's to not consider the safety implications of not having your side airbags. As this site typically does not recommend modifications that are not safe, I'm surprised at how some of you are taking to efforts of ensuring he evaluates what he's trying to do from all stand points and not just the convenience of comfort.
