Speed sensor
by Dammann35 » Sun Jan 12, 2014 8:31 pm
While drive the abs light and the brake light will come on and I plug my scanner on and it reads that the right front and the rear speed sensors. I forgot the codes that come up. Just wondering where the rear sensor is located. I read on trailvoy that it is in the transfer case. Anybody ever have this problem before?
Dammann35
by DustinC1989 » Sun Jan 12, 2014 8:45 pm
IIRC, 02-05 the rear speed sensor is on the back of the transfer case
DustinC1989
by The Roadie » Mon Jan 13, 2014 12:54 pm
Dammann35 wrote:...I read on trailvoy ...
Say WHAT? :poke: :slap:
Oh, OK....it's all right to use them as an archive if they show up in a Google search. :work:
by Trail X » Mon Jan 13, 2014 1:34 pm
Correct Dustin 06+ there are dual VSSs on the rear axle shafts.
There are two on the back of the transfer case, one is the rear propshaft speed sensor, which outputs to the TCCM, the other outputs to the PCM/ABS. I know Mario (Gordinho80) had an issue with his rear VSSs recently, you might be able to find some information from him about where it's located exactly.
