3.42+285=?
by Dammann35 » Wed Dec 18, 2013 9:35 pm
Has anyone ever ran 285/75R16 with the GU6 and no Tranny cooler?
Dammann35
by Moots1288 » Wed Dec 18, 2013 9:36 pm
I wouldnt suggest it. At least run it with a transmission cooler and aluminum wheels.
by Dammann35 » Wed Dec 18, 2013 9:39 pm
I still have the stock wheels that I would use.
Dammann35
by Moots1288 » Wed Dec 18, 2013 9:40 pm
Have you looked into 265/70/16 ?
by Dammann35 » Wed Dec 18, 2013 9:43 pm
I have 265/75R16 but I have the body lift on now and they look to small
Dammann35
by Moots1288 » Wed Dec 18, 2013 9:50 pm
by Dammann35 » Wed Dec 18, 2013 9:57 pm
How long did it take you to install your trans cooler
Dammann35
by Moots1288 » Wed Dec 18, 2013 10:03 pm
If I remember probably an hour.
by Dammann35 » Wed Dec 18, 2013 10:05 pm
Do you happen to know the part # for the cooler
Dammann35
by mikekey » Wed Dec 18, 2013 10:17 pm
Lol I have mine listed in my build
by Aries » Wed Dec 18, 2013 10:26 pm
I'm running 265/75R16 with 3.42 gears, did over 240 miles highway miles today with out an issue. I stopped several time to check the tranny fluid, the dip stick was warm to the touch but not so hot that I could not touch it. And I even grip it tightly in my hand. With that said I do have plans to install a transmission cooler and fluid temp gauge.
This is the cooler I purchased
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_maxi-kool&174;-xl-transmission-oil-cooler-imperial_5670021-p
Aries
by mikekey » Wed Dec 18, 2013 10:46 pm
Yeah no one here knows what we're talking about. Do whatever you want.
by dvanbramer88 » Wed Dec 18, 2013 11:51 pm
I recommend a trans cooler and a gauge for anyone. (truck always had the cooler) but after having the temp gauge, I don't know how I lived without it.
You can use any universal cooler that comes with an install kit and you can get good sized ones for like $30-50 bucks. Or you can go top of the line racing cooler with braided lines and spend a whole lot more like Moots.
Aries wrote:I stopped several time to check the tranny fluid, the dip stick was warm to the touch but not so hot that I could not touch it. And I even grip it tightly in my hand.
Because that is scientific...
mikekey wrote:Yeah no one here knows what we're talking about. Do whatever you want.
What he said
by DirtyBacon04 » Thu Dec 19, 2013 7:09 am
mikekey wrote:Lol I have mine listed in my build
Mine too.
I ran 3.42 + 33"s for about a year before I installed a xmsn cooler... I just about destoyed my original trans doing it (Lots of long road trips to and from trails, plus a CA to FL trip). If you're going to run that combo (which I dont recommend) a xmsn cooler will only delay the inevitable. Kinda like using a garden hose on a forest fire...
by wink » Thu Dec 19, 2013 5:06 pm
3.42+285= Overheated Trans
I ran without a trans cooler for about year also. Not a smart idea.
wink ;>
my build
wink
by Conner299 » Thu Dec 19, 2013 9:57 pm
I've got 255/70-16's and 3.42's currently. With a loaded truck of camping gear, and 70ish ambient air temp, I was hitting as high as 217 tranny temp, at highway speeds. At least according to Torque, I was. I plan on bigger tires, nothing bigger than 31's, but holding out till I can get my 3.73's installed, and a tranny cooler.
Conner299
by Dammann35 » Fri Dec 20, 2013 11:18 am
I found a B&M super cooler on Ebay for 57. I am gonna order it and install it before I get my 285s. While running my 265s I haven't had a problem with it and the trans has been running around 210-220. Kevin (Wink) who built you Front bumper? Its one of the best I have seen.
Dammann35
by DirtyBacon04 » Fri Dec 20, 2013 3:54 pm
Dammann35 wrote:I found a B&M super cooler on Ebay for 57. I am gonna order it and install it before I get my 285s. While running my 265s I haven't had a problem with it and the trans has been running around 210-220. Kevin (Wink) who built you Front bumper? Its one of the best I have seen.
I think I bought one from Advance Auto for about $30 somethin'.
Read his build thread; it's an MDB bumper.
by Dammann35 » Fri Dec 20, 2013 6:08 pm
I seen who is was made by after I took a double look at his build.
Dammann35
by Dammann35 » Fri Dec 20, 2013 6:53 pm
I also just ordered my trans cooler off ebay. Is there anything that I should do before I get 33's so I don't go bomb while driving.
Dammann35
