Front Bumper Cover
by Dammann35 » Sun Oct 13, 2013 3:12 pm
Hey guys. Im havinh alittle trouble getting my front bumper cover back on after the body lift. Anyone know any tricks or have any ideas to getting it line up.
Dammann35
by ErikSS » Sun Oct 13, 2013 3:59 pm
Did you relocate your front bumper? The steel bumper enforcment needs to be relcated after a body lift.
by Dammann35 » Sun Oct 13, 2013 4:03 pm
Yeah i have the bumper on and the whole body lift done but i am just havimg trouble lining up the bimper cover
Dammann35
by The Roadie » Sun Oct 13, 2013 4:40 pm
Sheet rock screws. Lotsa sheet rock screws.
by Opeth » Sun Oct 13, 2013 4:48 pm
Did you trim the 3 vents on the bottom of the bumper cover enough? If you did all the trimming on the steel bumper and relocated that properly, the cover will literally go right back on. The side circular tabs just need a quick jab to pop back into their respectful retainers on the bumper cover.
by ErikSS » Sun Oct 13, 2013 5:39 pm
If you can be more specific with what doesn't line up right, we might be able to be more specific with things to check!
by TBYODA » Sun Oct 13, 2013 5:50 pm
ErikSS wrote:If you can be more specific with what doesn't line up right, we might be able to be more specific with things to check!
I am thinking a picture would help the guys that have body lift to help you. Just saying.
by Dammann35 » Sun Oct 13, 2013 6:07 pm
On the sides with the tabs. When i pop the tabs back in they slide back out and wont stay in.
Dammann35
by ErikSS » Sun Oct 13, 2013 6:22 pm
I believe you have to pull them out a little, an back towards the wheel well pretty firm and let them slide forward into position.
by Opeth » Sun Oct 13, 2013 6:52 pm
Push harder...I had to give mine a good slap with my hand to get them to lock back into place.
by mikekey » Sun Oct 13, 2013 8:47 pm
Yeah pull hard.
by Dammann35 » Sun Oct 13, 2013 9:45 pm
it slides in but then pops out and wont stay in. I think it maybe because I cut the wings off the of the bumper so its not supported on the outsides.
Dammann35
by ErikSS » Sun Oct 13, 2013 9:48 pm
Pics please
by navigator » Mon Oct 14, 2013 8:02 am
when I trimmed the 3 vents in the front, It seemed I was almost to the point of cutting them out before everything would line up. One of my side snap pieces came off so I just used sheet metal screws to basically screw the bumper cover to the fender liner to hold it in place.
by Shdwdrgn » Mon Oct 14, 2013 11:28 am
Just give in and get a steel bumper... that solves everything! :)
Shdwdrgn
Contributing Author
by v7guy » Mon Oct 14, 2013 12:36 pm
Well, if you push the tabs in on the sides, and they lock in and then pop off, then it stands to reason there's something pushing forward on the sides. The problem is that there's not really anything over there.
by navigator » Mon Oct 14, 2013 1:04 pm
my problem was not getting enough trim on the vents. Them pushing up from the bottom would make the sides pop out.
by Dammann35 » Mon Oct 14, 2013 1:40 pm
I'm pretty sure that the frame is pushing the bottom of the bumper out like Navigator said.
Shdwdrgn I wish I had the money I would totally get a Steel Bumper.
Dammann35
by v7guy » Mon Oct 14, 2013 1:54 pm
then you gotta trim more. Generally, as mentioned, you gotta virtually completely remove the vents.
by navigator » Mon Oct 14, 2013 2:19 pm
BTW, if you use something like an angle grinder, be very careful of that hot plastic that is flying off :-)
Also, I think mine was more hitting the radiator skid vs the bumper mounting. I'm running the Zone 2" BL.
