no shift from 2 to 3
by motorhead1117 » Thu May 09, 2013 9:10 pm
I busted a trans line on interstate 3 weeks ago fixed with sawsall and rubber hose no leak since but trans sliped in 2 to 3 shift for a bit and now wont sift in 3 at all had to drive home in 2nd gear at 2500 slow any help is mutch appreciative thanks
motorhead1117
by dvanbramer88 » Thu May 09, 2013 9:28 pm
How long did you run the trans low on fluid?
After the fix, Did you immediately top off the transmission fluid to the correct level?
While checking trans fluid level, was the motor running with the trans in park?
by motorhead1117 » Thu May 09, 2013 9:40 pm
dvanbramer88 wrote:How long did you run the trans low on fluid?
i pulled over when the line busted and got a rollback to take me home fixed the leak added 4 quarts fluid and checked in park warm shifted through gears rechecked drove for three weeks after, noticed a small delay in 2-3 shift then no shift ??
motorhead1117
by mikekey » Thu May 09, 2013 10:03 pm
Bye bye transmission.
Is it throwing a code. When I lost the 2-3 solenoid even replacing it didn't seem to save me from the inventible rebuild.
by dvanbramer88 » Thu May 09, 2013 10:04 pm
I'm no expert but i think the 2-3 shift problem is not related to the line busting.
here is an excerpt from "common 4L60E failures" that apply to you
-No 3rd or 4th gear: “3-4” clutches are worn out. Remove & Replace.
by Trail X » Fri May 10, 2013 9:27 am
You may have done this already, but I didn't see you note it - have you checked your fluid level again since your fix?
In my experience, rubber hose over steel line never holds as well as you think, even if you don't see a leak... also if the hose isn't rated for transmission fluid, it can leak directly through the hose, not just at the ends. I learned that one from experience.
by motorhead1117 » Sat May 11, 2013 9:47 pm
did not leak any more fluid dont see any thing in fluid i will drop the pan in morning to see if any clutch fibers or metal if not got two shift solinoids and filter kit so guess we will see thanks for all the info guys
motorhead1117
by motorhead1117 » Sat May 18, 2013 5:55 pm
ok guys i finally had time to drop the pan and the fluid was dark with a little metal flake so new trans or new filter and shift solinoids
motorhead1117
by Trail X » Mon May 20, 2013 10:44 am
What is happening after 2nd gear? Is is neutral shifting? Is it high revving after 2? Or is it just locking in 2nd and not even attempting the 3 shift?
Depending on your answer, it could be various things.
Also, do you have any dash lights on? ABS light?
