Window Vent Rain Deflector (Removal)
by HuskyWagon » Fri Nov 18, 2011 2:49 pm
My first order of business is to remove some plastic rain deflectors that came with the TB we recently purchased.
So it appears that the plastic rain deflectors are held on with double sided tape. Could probably just gently pull these off with no problem, however my question really resides in how to properly remove any glue residue without scratching or affecting the paint?
Would a product like GooGone work for this situation? Any success stories?
I know this seems like a novice question but any thoughts/recommendations are appreciated.
Thanks
HuskyWagon
by janesy86 » Fri Nov 18, 2011 3:13 pm
Have had mine on for 3 years now, haven't tried/had the need to remove them, but if were to I'd apply heat (hair dryer, etc) since its colder out and see if they loosen a bit. But most likely use a piece of fishing line, as I did with the badges. And then yes, clean up with goo gone. Goo gone took the remaining glue/tape off that the badges left.
by HuskyWagon » Fri Nov 18, 2011 3:39 pm
Thanks for the advice. Glad to hear that this method worked on the badges as well.
HuskyWagon
by Trail X » Fri Nov 18, 2011 3:40 pm
Don't worry about scratches, you'll get plenty if you're wheeling your vehicle. Take a plastic putty knife and go to town. :fro:
by The Roadie » Fri Nov 18, 2011 5:37 pm
Putty knives come in plastic? :finger: I use a dull chisel on residual glue that fails to come off with a wood rasp. :friday:
by MrSmithsTB » Fri Nov 18, 2011 7:37 pm
Heat gun and a nice tug will get the guards and most residue in one shot. Goo gone will take care of the rest.
by NC_IslandRunner » Fri Nov 18, 2011 9:21 pm
Used Goo Gone on my Moms sunroof visor residue it is Goo God :D
by Skidder » Sat Nov 26, 2011 10:08 am
Strangely enough...peanut butter. But use creamy, not chunky...Ha. Seriously, the oil in peanut butter does a really good job on adhesive residue.
Skidder
by lil_freak_66 » Sat Nov 26, 2011 1:42 pm
not sure i wanna ask how/why you found that one out....
Michigan Search & Rescue.
SARTECH III
lil_freak_66
by MrSmithsTB » Sat Nov 26, 2011 4:50 pm
I've found the chunky works much better with my sandwiches.
