bgwolfpack wrote:fishsticks wrote:
Aside from converting to rear sump of course.
I've not seen a rear sump pump for the I-6 engine nor would one work with the configuration of that pan.
I think you are best off to run the oil at the proper level and limit your incline attacks to as short of time as possible. If you're trying an incline the truck is not capable of getting up or over in a reasonable amount of time then you should rethink other configurations of the Fishmobile itself and not abuse the engine instead. 2cts
Of course it would require a new pan, there is a cast pan that efi-diy made on the OS that I believe requires sump relocation.
I tend towards the "slow and steady wins the race" brand of wheeling. So -my- reasonable amount of time may be longer than others.
This is rapidly going to become a limiting factor for me, and if I can't get past it then any future mods I would do are kind of moot.
Even this caused my DIC to scream:
It's frustrating that the truck will happily climb up anything the tires will bite into but oil starvation will keep me off of things anyway.
Think I will just try an extra quart and see if I get foam.
02 TrailBlazer LTZ - 35s, lockers, balls - Gone but not forgotten -
Build
