Tools!
by The Roadie » Tue Mar 17, 2015 10:09 am
I just put in the Massive adjustable rear control arms and had to buy a 24mm wrench. Shocked me to be buying new tools after ten years with the Roadiemobile.
by DirtyBacon04 » Tue Mar 17, 2015 1:56 pm
I just lather up that taper with anti seize and haven't ever had an issue getting it off.
by Jrgunn5150 » Tue Mar 17, 2015 2:25 pm
The taper the bottom of the strut goes in?
by DirtyBacon04 » Tue Mar 17, 2015 7:03 pm
yes, where the strut meets the LCA. I get a lil anti-seize happy during maintenance.
by Jrgunn5150 » Wed Mar 18, 2015 8:03 am
Sweet! I'll have to give that a shot
by Regulator1175 » Sun Mar 22, 2015 11:37 pm
10, 12, 13, 15, 18, 22, 36 mm sockets will do just about everything you will need. Carry both 1/2 and 3/8 sizes as well as box wrenches. Breaker bar and ratchets for both sizes. Two good screwdrivers, good set of pliers, needle nose, channel locks and pipe wrench. 9 inch piece of steel bar / pry bar, pickle fork, 5lb sledge with short handle, tin snips (they have come in handy a few times for me for making in the field clearance adjustments. With those tools, and more importantly the spare parts, you should be able to solve most problems while in the field. That said, I fit in the same category as Mike above, I carry a pretty complete tool set with me. I joke all the time that I can do a complete motor swap with the tools in the back of my truck. The truth is that I not only can do a motor swap, but a transmission overhaul, any field repair, and harvest any part needed from a salvage yard. I have done all of the above out of the trunk of my truck!
by Jrgunn5150 » Fri Mar 27, 2015 11:20 am
Well it looks like the lower strut mount is 22mm,and of course both my crappy set stop at 21 lol.
This is why I do dry runs I suppose
by Jrgunn5150 » Fri Mar 27, 2015 12:27 pm
Fail... Its not 22 either lol
by v7guy » Fri Mar 27, 2015 12:48 pm
You guys could just be updating this thread... viewtopic.php?f=11&t=4976
Just sayin
I'll go back and edit the original post as more specifics get brought up, it'll make it easier for future reference. If we continue to post good stuff i'll merge em.
by Jrgunn5150 » Fri Mar 27, 2015 1:02 pm
v7guy wrote:You guys could just be updating this thread... viewtopic.php?f=11&t=4976
Just sayin
:Iagree: looks like I fail again, just not my day lol. Thanks!
