Squeaky Steering Wheel
by dvanbramer88 » Wed Dec 19, 2012 11:42 am
v7guy wrote:Sounds like the wheel is rubbing on something... but I'd be more worried about getting some gas in that mofo. You can ruin the pump suckin up sediment in the tank.
Old wives tail. I was in my 15 year old gas tank to do a fuel pump a couple of winters ago. Clean as a fricken whistle in the tank. Also, the pump's filter is basically jambed against the floor of the tank. The pump always draws from the very bottom, no matter how much fuel is in the tank.
But there is another argument, that the fuel cools the pump. Running the pump with the tank empty can overheat the pump and shorten its life if done frequently.
Which, IME, might be true. The fuel pump died on me after 2 years of being a poor highschool kid and only putting 20 bucks in the tank at a time. I literally had a 1/4 tank of gas for 2 years.
by v7guy » Wed Dec 19, 2012 1:01 pm
I dunno then, my firebirds tank had all sorts of gunk in it when I pulled it at about 10 years old. It was probably left over from when we all got pissed at it and started pouring sand in the tank... yeah, now that I think about it, that's definitely it. :raspberry:
But seriously, I've personally seen build up in tanks. It happens.
by Conner299 » Wed Dec 19, 2012 2:32 pm
Yeah... i usually just fill up every Friday. According to my aCar app for android, I'm getting 15.359 mpg. Ive usually got 230 miles on the trip meter. Soo... That's approx 6.5 gallons left in the tank... I love my aCar app, and it was FREE.
Conner299
by mtb34 » Fri May 10, 2013 12:57 am
steering wheel has been squeaking almost since I bought it in 2008 ... sounds like rubber on rubber ... too much trouble to figure out what it is ... I did look at the steering column linkage the other day where 2 rubber boots come together in the engine compartment ... there was a metal ring that looked like it was supposed to hold the boots together ... just some sprung steel ... it had fallen down inside of the lower boot ... dont know wtf that thing was for and could figure out where to put it back at ... guess it wasnt necessary so I eliminated it ... thought the squeaking might be from those 2 rubber boots coming together but I dont think the noise could make it through the firewall ... I need to pull the steering wheel inside and see if I can figure it out ... noise is exactly the same as yours
mtb34
by DirtyBacon04 » Fri May 10, 2013 4:03 am
my truck made that exact noise, too!
Don't know if it was related or coincidence, but when I changed my PS pump (for other reasons)... the sound went away.
by v7guy » Fri May 10, 2013 4:42 am
mtb34 wrote:steering wheel has been squeaking almost since I bought it in 2008 ... sounds like rubber on rubber ... too much trouble to figure out what it is ... I did look at the steering column linkage the other day where 2 rubber boots come together in the engine compartment ... there was a metal ring that looked like it was supposed to hold the boots together ... just some sprung steel ... it had fallen down inside of the lower boot ... dont know wtf that thing was for and could figure out where to put it back at ... guess it wasnt necessary so I eliminated it ... thought the squeaking might be from those 2 rubber boots coming together but I dont think the noise could make it through the firewall ... I need to pull the steering wheel inside and see if I can figure it out ... noise is exactly the same as yours
That clip fits inside the rubber piece and helps it clip into a groove on the hard plastic piece to secure the boot.
by Regulator1175 » Sun May 12, 2013 2:41 pm
My Bravada has that same sound. The radio is always on though, so I don't even hear it until I go through the fast food drive thru or the bank teller.
