Fender Flares Everyone should know about
by SaltWaterDrinker » Wed Aug 01, 2012 5:27 pm
Agreed Mario - much bigger tyres needed!
SaltWaterDrinker
by Nakashige » Thu Aug 02, 2012 3:51 am
anyone know what these are from
Nakashige
Vendor
by Trail X » Thu Aug 02, 2012 8:29 am
charliesrobinson wrote:... Bushmaster makes it. Only it is for the Jeep Cherokee. They are the Bushmaster Cut Away Bolt-on for a mid 90's Cherokee. ...
by navigator » Thu Aug 02, 2012 8:38 am
I don't know which ones he got but if I remember right the body style changed in 97 (drivetrain in 96) so I would expect the 96 and 97 flares would be different.
by JCrayton99 » Thu Aug 02, 2012 9:48 am
So are we going to assume a pre 96?
JCrayton99
Rank: Offroad Guide
by Rob93 » Thu Aug 02, 2012 10:00 am
The flares fit all 84-01 cherokees. In 97 the tail lights changed as well as front clip but the body lines are the same.
Rob93
by Nakashige » Thu Aug 02, 2012 12:19 pm
looks like I might get a set
Nakashige
Vendor
by JCrayton99 » Thu Aug 02, 2012 12:23 pm
Definately will look better than the cob job I was about to start....
JCrayton99
Rank: Offroad Guide
by HARDTRAILZ » Thu Aug 02, 2012 12:49 pm
I got some stock xj ones and they seem to be a close fit
by Nakashige » Thu Aug 02, 2012 1:26 pm
I have a set off of a yj i might try first
Nakashige
Vendor
by Camotyger » Thu Aug 02, 2012 1:29 pm
IDk about them, something just looks wrong. Ive seen the same ones on jeeps all over Ft. Campbell and I just cant picture them on my TB..
Camotyger
by navigator » Thu Aug 02, 2012 2:17 pm
They look gaudy to me.
If you must have them for law/safety reasons I can understand but if not I would leave them off.
I guess everyone has their own tastes though else we would all be the same.
by HARDTRAILZ » Thu Aug 02, 2012 2:32 pm
Jk ones are way different. Fyi.
by Nakashige » Thu Aug 02, 2012 10:33 pm
I know i got yj ones for free worth a try
Nakashige
Vendor
by v7guy » Thu Aug 02, 2012 11:02 pm
Well, now I just wonder why charlie never came back and posted more.
The bottom front of the rear flare looks a little off to me. But everything else looks great. Could cram even bigger tires in there and it would look even better. Too bad there's not a dozen more pics from half a dozen angles or more.
by Rob93 » Fri Aug 03, 2012 12:42 am
I really cant imagine tj ones looking very good. But I guess you could try
Rob93
by dirty anton » Fri Aug 03, 2012 5:48 pm
ben if your axle is pushed back a few inches like mine and steves the flares might go in kinda funky. plus there is an off set cut out on the bottom of each end of the flares for i guess the contour of the molding. a friends shop had some of these and i was able to check a set out for a 96 cherokee. i would have to offset these and really do some cutting and blending to even come close to looking right for my truck. im on the fence........ but dont see really any issues with installing these on a stock axle location. just a little blending of the bottoms of the flares if it matters to you.
dirty anton
by Diacom » Sat Aug 04, 2012 11:55 pm
hobbstisdaman wrote:
Don't see how that lines up with us though...
I helped install a set of this type on a jeep, before hand, I took them out to my TB and tried setting them against the body to see how they might fit due to our inablility to have some made for our vehicle.
They would not fit w/o modifying. The bottom of the jeep curves in a bit more at the bottom than our vehicle does.
For some reason, I couldn't convince my friend to let me work on fitting them to my TB instead of his cherokee... some friend... J/K
So while he has pics with them on, it wasn't a direct bolt on, there had to be some modding done to fit them properly.
by Nakashige » Mon Aug 06, 2012 12:49 am
I need to come up with something I guess in MA a tire sticking out beyond fender is a 200 per tire fine. This is what I have heard from others
Nakashige
Vendor
by janesy86 » Mon Aug 06, 2012 8:29 am
I've been drivin the Jeep around without rear flares. No looks from cops at all. I'll run like this til I get hassled and throw them on for inspections.
