Bluetooth OBD2 adapter + Torque = Scangauge on crack.
by HARDTRAILZ » Tue Jan 18, 2011 12:10 am
Other than cd it is a great tool for the price. Thanks to matt for helping figure out syncing up the droid. I had an issue with my old card being on my google account so just got the free torque and it works well and did what I needed. Will change card info and see what extra the pay torque app has.
I did havea p0411 code again. Had at tecore and seem to pop it after slow wheeling for a few hours.
by wink » Mon Feb 07, 2011 3:41 am
Any more reviews on this? Was it worth purchasing? I'm getting tired of running to Autozone for code reads.
wink ;>
my build
wink
by HARDTRAILZ » Mon Feb 07, 2011 4:01 am
Definitely worth it to read codes. There is even a free app from torque. Cheap to play with and check and clear codes.
by fishsticks » Mon Feb 07, 2011 8:39 pm
HARDTRAILZ wrote:Definitely worth it to read codes. There is even a free app from torque. Cheap to play with and check and clear codes.
I'm definitely satisfied with the price/performance.
by Zero » Mon Feb 07, 2011 9:09 pm
what does this do that the scangauge wont?
by Philberto » Mon Feb 07, 2011 9:20 pm
Zero wrote:what does this do that the scangauge wont?
Cost less than $100 :poke:
by Kuchar09 » Tue Feb 15, 2011 5:14 pm
I think I have gotten the Transmission Temperature to work, kinda.
I finally got my OBD II reader yesterday and Torque and started messing with it and I got the transmission temp to show, but it seems like it only shows once and never updates like the coolant temp.
I add the custom PID 221940
with the equation
((A-40)*(9/5))+32
At first it didn't work but while I was heading to the store it displayed a temp of about 150 degrees Fahrenheit, but it seemed like it only updated once.
I want you guys to give it an try to make sure this isn't a fluke.
http://torque-bhp.com/forums/?wpforumaction=viewtopic&t=346.00
Kuchar09
by fishsticks » Tue Feb 15, 2011 5:26 pm
Good show. I meant to register on there and ask about trans temp but hadn't gotten around to it.
by madmanvillain » Tue Feb 22, 2011 12:37 am
Mine shipped today....excited to get it in and start playing
madmanvillain
by rjpoog1989 » Mon Mar 28, 2011 7:15 pm
So I'm definitely either doing this or getting a Scangauge as going to AutoZone for codes has become rather annoying. I've gone like twice in the past month, once for each vehicle (TB and Shitfire), only to receive the same code with each (p0442 - emissions systems leak).
I have a Droid, so getting the adapter/app seems like the easiest, cheapest, and overall best way to do this. I just wanted to check with yinz to make sure my logic was sound...? What differences (if any) are there between the Torque app and the Scangauge? Has someone figured out how to keep an eye on the Transmission temp with the Torque app?
Thanks in advance!
Ryan
Rule #76: "No excuses, play like a champion"
rjpoog1989
by fishsticks » Mon Mar 28, 2011 10:18 pm
rjpoog1989 wrote:So I'm definitely either doing this or getting a Scangauge as going to AutoZone for codes has become rather annoying. I've gone like twice in the past month, once for each vehicle (TB and Shitfire), only to receive the same code with each (p0442 - emissions systems leak).
Thanks in advance!
I'm beginning to believe that 2002 models don't have a trans temp sensor, which is why I've been unable to monitor mine. The PID for it is in Torque already.
by Philberto » Wed Mar 30, 2011 4:46 pm
Just picked up one of these for $20, got a CEL still, and now that I'm not with the dealer, not so cost-effective to get it checked anymore. Really hoping it'll help me out with my 10-ish mpg problem :hissyfit:
by madmanvillain » Wed Mar 30, 2011 7:55 pm
Not sure if the 04 has one either i cant get trans temp either...what about fuel quantity? Can you get one?
madmanvillain
by rjpoog1989 » Wed Mar 30, 2011 8:59 pm
Philberto wrote:Just picked up one of these for $20, got a CEL still, and now that I'm not with the dealer, not so cost-effective to get it checked anymore. Really hoping it'll help me out with my 10-ish mpg problem :hissyfit:
Most of them that I've seen are around 40$. I'm trying to find one a bit cheaper, and doing research to make sure it's exactly what I want. Does anyone know if the CD for computers is Mac compatible? I assume it's not, as few things of this nature are, but just curious... My desktop is still a PC but my laptop is a Mac so I was hoping I could use that as well as my Droid.
Ryan
rjpoog1989
by Philberto » Fri Apr 01, 2011 3:34 am
From what I've heard, the software that comes with it is incredibly outdated and old. That said, it's bluetooth, so if you download or purchase newer software, it should interface with most any bluetooth-enabled pc at least. I'll let you know when I get it. I just found a good deal... Just search on google shopping for obd2 bluetooth and you'll be set.
by djthumper » Fri Apr 01, 2011 10:50 am
You can run it on the Mac. If you have Wine, Parallels, or VMWare fusion with windows loaded. You can even run bootcamp and reboot into windows.
by rjpoog1989 » Fri Apr 01, 2011 11:05 am
djthumper wrote:You can run it on the Mac. If you have Wine, Parallels, or VMWare fusion with windows loaded. You can even run bootcamp and reboot into windows.
I'd really rather not run Windows, just using Microsoft Office daily is enough to piss me off, let alone going back to using Windows. Too many viruses and other garbage associated with it. Assuming it's not Mac compatible, just using my Droid should work out fine.
Ryan
rjpoog1989
by TangoBravo » Fri Apr 15, 2011 9:31 am
Anyone suggest a certain brand Bluetooth obd2 adaptor?
TangoBravo
by The Roadie » Fri Apr 15, 2011 10:18 am
I just got a $20 cheapie from EBay vendor tomtom. Worked fine but I had to Google for the nonstandard pairing code 6789. Came in about ten days from China.
Note: Chinese electronics are OK, and I've visited many of their plants. I just think they source a lot of suspension crap parts.
by Trail X » Fri Apr 15, 2011 12:15 pm
The Roadie wrote:Note: Chinese electronics are OK, and I've visited many of their plants. I just think they source a lot of suspension crap parts.
It's all in how tightly the parts are spec'd.
