I'd say in 4 lo it wouldn't be an issue, I've found that in my '09 Sierra 2500HD I drive for work that once it's in 4 lo it pretty does everything it's supposed to, but on an incline facing down, in reverse and 4 hi, it will not accelerate enough to back up the incline. Seems like it just holds the low RPM similar to what is being described by fishsticks as TM...
The situation was busting through some snowy trails, in 4 hi, first gear, tires spinning some, but with being held to a lower rpm, not as much as I would have liked. After the fact, I did consider maybe putting it into 4 lo and a higher gear would have been the best in this situation. It may be something I go back and test at a later date after another snowfall up in the mountains.
I'll get around to posting a short clip or 2 that illustrates the situation some.
