Help! How important is this wire?
by DeviousPizzaGuy » Mon Oct 31, 2016 1:54 pm
During installation of my rough ountry leveling kit, I found this loose red wire on driver side near the fuse box. I'm pretty sure it is supposed to connect to the third post on the fuse box, but I'm missing the nut..
DeviousPizzaGuy
Name: Derek J DeGroate
by DeviousPizzaGuy » Mon Oct 31, 2016 1:58 pm
Looking back, this may be better off in the troubleshooting section, but everything is working correctly as far as I know.
DeviousPizzaGuy
by HawkeyeC25 » Mon Oct 31, 2016 9:20 pm
This looks like the wire that powers your 12V feed to you 7-pin wire harness in the bumper. This will allow you to feed 12V power to your trailer. It can be hooked up to a powered Stud under the neighboring fuse block.
HawkeyeC25
by bartonmd » Mon Oct 31, 2016 11:19 pm
Craig is correct. Also, it doesn't come with a nut on that stud, but it's an M6, IIRC.
by DeviousPizzaGuy » Tue Nov 01, 2016 1:40 am
Thank you both!
DeviousPizzaGuy
by HARDTRAILZ » Tue Nov 01, 2016 9:04 am
I thought it was the self destruct wire and not to touch it?
by DeviousPizzaGuy » Tue Nov 01, 2016 2:20 pm
I'm assuming that it's disconnected for a reason, so it may BE the self destruct wire if I try to hook it back up lmao
DeviousPizzaGuy
by mason10198 » Tue Nov 01, 2016 3:48 pm
It's the power wire for the trailer harness. It comes disconnected from the factory on like every 360 for some reason.
Sent from my SAMSUNG-SM-G870A using Tapatalk
by bartonmd » Tue Nov 01, 2016 8:00 pm
mason10198 wrote:It's the power wire for the trailer harness. It comes disconnected from the factory on like every 360 for some reason.
For the same reason that the trucks' trailer power wiring comes from the factory without a fuse in it.
by KingBird » Thu Nov 03, 2016 10:04 pm
So, who else misses Roadie?
KingBird
by DirtyBacon04 » Thu Nov 03, 2016 10:37 pm
KingBird wrote:So, who else misses Roadie?
I was hoping he would sense that someone asked this question and he would make an appearance...
by Trail X » Fri Nov 04, 2016 8:59 am
Yeah, his normal image response would be great right about now... alas, his head is in the clouds.
by HARDTRAILZ » Fri Nov 04, 2016 9:20 am
Beyond the clouds....
by DirtyBacon04 » Fri Nov 04, 2016 11:44 pm
to infinity...
by bljis123 » Wed Nov 09, 2016 11:36 am
Ohhhhhhhhh Mistery solved. I thought it may be some time of heater for up north... LOL
2003 GMC Envoy XL SLT 4x4
bljis123
Vehicle: GMC Envoy XL
