No 4wd, no switch lites, no service lite
by rosier1 » Sat Dec 14, 2013 2:09 pm
I have yet to find my exact problem on this awesome, informative and very helpfull site. I have an 02 Trailblazer with 79k very gingerly and well maintained miles and my 4WD is not working. Fluid changed at 50k, 4 years ago. My Mode Switch lights are not lit, never noticed when they stopped working. I am an idiot! Also not lit is my service 4WD light on the dash. I pulled fuse #8, looks fine, did the 30 second wait. Pulled fuse #48,looks fine also. When I tried it in September of this year it all worked fine. I try it every couple of months to make sure it works, but got caught in a snowstorm last weekend and nuttin. I am hoping TCCM. Any thoughts would be greatly appreiciated!! And where is the TCCM? Steering column?
BTW......Krylon Fusion painted bumpers that I did in August are still looking great, no changes to them yet!
rosier1
by ErikSS » Sat Dec 14, 2013 2:50 pm
I am NOT an expert in auto electric, but I have 1 idea. If the service 4x4 light isn't on, it seems the self diagnostic system hasn't detected a problem. The lights don't come on the switch, and 4x4 doesn't work. After checking fuses as you have, that would lead me to the switch itself. They can be bought at Carquest pretty reasonble.
by DirtyBacon04 » Sat Dec 14, 2013 2:58 pm
ErikSS wrote:I am NOT an expert in auto electric, but I have 1 idea. If the service 4x4 light isn't on, it seems the self diagnostic system hasn't detected a problem. AThe lights don't come on the switch, and 4x4 doesn't work. After checking fuses as you have, that would lead me to the switch itself. They can be bought at Carquest pretty reasonble.
:Iagree:
Easy fix.
by Moots1288 » Sat Dec 14, 2013 3:29 pm
Yup.. it's problematic on the 02s
by TBYODA » Sat Dec 14, 2013 3:39 pm
Not sure if this part is any good or not
Dorman 901-064
http://m.summitracing.com/parts/rnb-901-064 about $18
Amazon same on prime
Rockauto
http://www.rockauto.com/catalog/x,carco ... type,10775
by rosier1 » Sat Dec 14, 2013 3:55 pm
Thanks guys!! Easier fix than I planned on. Another dumb question. How to remove the switch?. Pull the dash panel apart?
rosier1
by DirtyBacon04 » Sat Dec 14, 2013 4:06 pm
Hammer... the bigger the better...
by The Roadie » Sat Dec 14, 2013 9:07 pm
The switch pries out. But let's back up a second. When you turn the ignition on, the lights on the switch should all come on for a second as a lamp test. Does this not happen?
For a 2002, the TCCM is a huge suspect, but when they fail, the PCM detects the lack of communication and turns on the "Service 4WD" lamp. If this isn't happening for you, you may have something unique to troubleshoot. Do you have a voltmeter and any experience in electrical troubleshooting?
The TCCM is above the driver's left knee, mounted to the top side of the trim panel underneath the steering wheel. Here's a picture, but I guarantee you will not have to disassemble your dash to this extent to see it.
by rosier1 » Sun Dec 15, 2013 2:15 am
No lights on the switch at start up. No lights at all, thats what makes me suspect the switch. I do have a volt meter and am not afraid to use it.
rosier1
by Regulator1175 » Sun Dec 15, 2013 3:18 am
With no lights at all I would certainly look at the switch as the problem. Any friends around with a Trailblazer that wouldn't mind helping you do some trouble shooting? Try a functioning switch from another truck and see before you spend the money. Maybe a test drive from a local car lot?
by rosier1 » Sun Dec 15, 2013 1:01 pm
I ordered 1 from amazon to get me through for now. $30 delivered. But want a better brand name. Just gotta get it working now.
rosier1
by The Roadie » Sun Dec 15, 2013 1:21 pm
The lamp test at ignition ON time depends on a working TCCM, but it also depends on a good dimmable lamp bus connection. Are any other interior/dash lamps out? If many of them are out, then it could also be a blown TBC fuse (2, or 4, I forget which one feeds the mode switch). Or of course front fuse #8.
If you have the schematic, I'd be putting a meter on the back of the switch while you wait for the replacement to arrive. Look for 12V on pin B, purple/white. That's the dimmable lamp feed that is required for the lamp test. And look for 5V on pin J, a gray wire. And somethign lower than 5V on pin K, light blue, and that voltage will vary depending on the mode the switch is in.
by rosier1 » Sun Dec 15, 2013 3:03 pm
Actually I just noticed that the light on the battery or oil is out. Its the one on the top right, closest to the switch too. Damn man, your good! I will go check fuses as soon as I can. Thanks a bunch!!
Sent from my SCH-I535 using Tapatalk
rosier1
by rosier1 » Sun Dec 15, 2013 3:19 pm
Fuses are good.
rosier1
by The Roadie » Mon Dec 16, 2013 12:34 pm
So check to see if the voltage from the good fuse gets delivered to the switch on the pins I posted.
by rosier1 » Sat Dec 21, 2013 1:02 pm
Replaced switch. No change. Found a TCCM at a local junkyard for $85. My mechanic buddy is going to see if it threw a code. I wonder if it were to be flashed, it'll straighten out. Breaking out the meter first.
rosier1
by rosier1 » Thu Dec 26, 2013 6:26 pm
Hooked up the Snap on scanner. Got a U1000 code. Still no lights on the switch, even at startup. Still no service 4wd light either.
rosier1
by The Roadie » Thu Dec 26, 2013 7:04 pm
Checked any of the voltages on the TCCM or the switch yet?
by rosier1 » Thu Dec 26, 2013 7:26 pm
All the voltages are what they should be. The TCCM is communicating with the code reader. Code U1000 class 2 comm problem.
rosier1
by The Roadie » Thu Dec 26, 2013 9:06 pm
Hmmm, pull stuff out of the data comm splice packs until the tccm communicates with the pcm? You sure have a weird one!
