Front end clunk
by Moots1288 » Sat Sep 07, 2013 7:42 pm
I've been having a front end clunk that's been going on in slow speed to a dead stop at full lock. It does not happen above 20MPH. I have checked the tie rod ends and replaced the ball joints. I also swapped in HD TREs and when i did that I found out that the spindle was to large and me and V7guy made a sleeve for it, he also did that for his and it has been working fine, there is no play in the rod end when I wiggle it back and forth. Seems that it only happens when there is full pressure on the front end. Anyone have any ideas?
by DirtyBacon04 » Sat Sep 07, 2013 7:53 pm
Hmmm... is it just driving straight at under 20mph? Or are you saying only when you hit final resting at a stop? Does it happen at all in relation to suspension flex? If so, could be UCA bushings. Coming from both sides or can't tell?
Ok, i just re-read it again. Are you saying at full lock left/right while coming to a stop? Does it happen every time or just random?
by Moots1288 » Sat Sep 07, 2013 7:56 pm
DirtyBacon04 wrote:Hmmm... is it just driving straight at under 20mph? Or are you saying only when you hit final resting at a stop? Does it happen at all in relation to suspension flex? If so, could be UCA bushings. Coming from both sides or can't tell?
Sorry.. I didn't add it in, full left or right everytime at full lock as soon as I'm about to hit the steering stop. It jerks the whole truck.
by dvanbramer88 » Sat Sep 07, 2013 7:58 pm
IIRC, you recently replaced the control arms and have new control arm bushings. Are your strut (coil over) mounts tight?
by ErikSS » Sat Sep 07, 2013 7:59 pm
From the experiences I have... I'd check the driver first. Full lock at over 20mph in a lifted tb, are ya crazy? haha
by Moots1288 » Sat Sep 07, 2013 8:00 pm
ErikSS wrote:From the experiences I have... I'd check the driver first. Full lock at over 20mph in a lifted tb, are ya crazy? haha
Haha hell yeah I'm crazy! And everything in the front end is torqued down.
by dvanbramer88 » Sat Sep 07, 2013 8:03 pm
Like this? lol That clunking would be the engine running upside down without any oil..
Matt, show us in the parking lot on TECORE. Just don't do this. ^
by Moots1288 » Sat Sep 07, 2013 8:10 pm
why can't I do that? Why are you taking all my fun away!
by dvanbramer88 » Sat Sep 07, 2013 8:14 pm
You can do it at 1pm when you're sitting in the Walmart parking lot by yourself.
by Moots1288 » Sat Sep 07, 2013 8:24 pm
I'm wondering if its the LCA bushings since the mevotech ballpoints where shot. Or the Rack an pinion
by v7guy » Sat Sep 07, 2013 9:06 pm
When I've noticed it the most is when he's parking, those slow maneuvers in tight areas. When he gets turned all the way it makes a clunk/pop. The bushings in those control arms are maybe 6-9 months old, I'd be really really surprised if they're the problem.
by Moots1288 » Sun Sep 08, 2013 11:18 am
After further analysis this morning by me and Jason we have come to a 95% conclusion that it is the rack. Yippy!
by Moots1288 » Sun Sep 08, 2013 3:55 pm
Found a Detroit axle rack and pinion with lifetime warranty reman, off eBay for 168$ free shipping what do you all think?
by dvanbramer88 » Sun Sep 08, 2013 5:34 pm
I know Kyle really likes the Detroit axle reman CV shafts so they seem to be a reputable company. Reman rack and pinion for your truck on rock auto range from $190 to $290 plus core charges and shipping.
I'd say $168 free shipping is a pretty ok deal.
by Moots1288 » Sun Sep 08, 2013 5:49 pm
dvanbramer88 wrote:I know Kyle really likes the Detroit axle reman CV shafts so they seem to be a reputable company. Reman rack and pinion for your truck on rock auto range from $190 to $290 plus core charges and shipping.
That's what I was thinking.. Plus lifetime warranty!
by dvanbramer88 » Sun Sep 08, 2013 5:50 pm
I agree.
by Opeth » Sun Sep 08, 2013 6:03 pm
Iirc I saw someone either here or GMT that was having a similar issue and ended up being his sway bar bushing where the bar mounts to the under body. I guess those rubber u shaped mounts failed. Or could be your rack.
by ErikSS » Sun Sep 08, 2013 6:14 pm
I had an issue with a clunk that was followed by an alignment issue on AJ (hotness) truck. Does your truck seem to do that? His was 1 loose bolt on the lower control arm.
by Moots1288 » Sun Sep 08, 2013 6:23 pm
Opeth wrote:Iirc I saw someone either here or GMT that was having a similar issue and ended up being his sway bar bushing where the bar mounts to the under body. I guess those rubber u shaped mounts failed. Or could be your rack.
I replaced those bushings as I saw that post also. And all my LCA bolts are tight.
by Trail X » Tue Sep 10, 2013 3:41 pm
Does it do it when the front end is lifted in the air? If so, get someone down there to take a look when you turn the wheel. If nothing else, trace out a repetitive pattern in a parking lot that creates the noise. Since its at low speeds, have someone walk along and try to locate the origin of the sound. Left side vs right side, front of the wheel well vs back of the wheel well, top vs bottom. Then you'll at least have a quadrant to begin looking closer at. I had one of these once, very similar, and it was that some of the "frame shield" at the front of the ifs subframe got bent into the lca and was rubbing. For some reason when doing slow parking maneuvers it bound up and would jump really odd-like. Finding it was a matter of performing the same thing I said above.
