Air Conditioning issue
by localarmyman » Mon May 20, 2013 2:23 pm
Hey guys i am sure this issue has been hit time and time again but for some reason when i search i am coming up empty handed, i just need to be pointed in the right direction, i have an 04 trailblazer and i also have the digital temp control, when i set the ac as low as it goes it will blow cold on the passenger side but warm on the driver side, it must just be some sort of temp control switch or something but like i said im just not finding the info, i hope you all dont mind helping me on what im sure is a dead issue but any info would be appreciated
“It is foolish and wrong to mourn the men who died. Rather, we should thank God that such men lived.”
― George S. Patton Jr.
localarmyman
by Wahugg » Mon May 20, 2013 2:50 pm
You probably have a blown or misaligned actuator on the drivers side. Re-align or replace.
-Wahugg
Wahugg
by localarmyman » Mon May 20, 2013 3:02 pm
that sounds right but i just dont know where to look for them or what to look for i just need more infor on what it is i need to look for and where basically
localarmyman
by plaen » Mon May 20, 2013 6:36 pm
localarmyman wrote:that sounds right but i just dont know where to look for them or what to look for i just need more infor on what it is i need to look for and where basically
This one describes it as the air mode actuator
and from the picture, searching on GMT, found this
The third post down on this GMT Nation Post should be a little more helpful.
Usually just a google search for actuator driver side air with site:gmtnation.com or offroadtb.com will give you good results
plaen
by The Roadie » Tue May 21, 2013 12:27 am
A temperature issue is caused one one of the two TEMP actuators. Losing the dash vent airflow (the most common failure) is caused by the airflow MODE actuator.
by localarmyman » Tue May 21, 2013 9:34 am
i am still able to switch between the defrost, floor, and face vents no problem, and it is pushing plenty of air its just warm on the driver when it should be cold so would that make it the Mode actuator, or the defrost-driver temp actuator?
localarmyman
by Trail X » Tue May 21, 2013 10:10 am
Logically, since your temperature on your drivers side is the only issue... I would replace the drivers temp actuator first.
by The Roadie » Tue May 21, 2013 11:18 am
JD is right. And don't forget to search for and read the threads on other sites that refer to the correct fuse to pull and the process to follow for recalibration after the actuator replacement.
by localarmyman » Tue May 21, 2013 11:45 am
thanks for all the help guys ill order the part today and get to work
localarmyman
by COUNTRYTBLS » Thu Jun 11, 2015 8:08 pm
The Roadie wrote:A temperature issue is caused one one of the two TEMP actuators. Losing the dash vent airflow (the most common failure) is caused by the airflow MODE actuator.
I am having the same issue. I'm no mechanic so what is this picture of? Because I think all of mine need to be replaced. I have NO AIR FLOW through any of my vents. I did about 2 days ago and it was cold so the temperature is not a problem.
I too had the same problem I have been searching for the past day on here and Gmtnation but come up empty handed on the search. This is the only relevant search I have found.
Any suggestions would be greatly appreciated.
COUNTRYTBLS
by TBYODA » Thu Jun 11, 2015 9:00 pm
Could be you fan motor and or resistor pack and connector. Search on that. Do you get any air flow at any speed?
