Installed Z71's and 10" Bilstein universal off road shocks with 255/70 valving. Similar compressed and extended lengths as bds fox shocks. Now while acceleration I get some vibrations that are speed/ torque related and feel/ hear them through the body. No vibes while coasting or doing an acceleration under 2500 rpms. I'm going to assume a u-joint since they are all original. Transfer case fluid changed last fall, diffs have not but this just started after these were added. Only at 79k miles.
Also I am getting clunking now, which sounds as if like the blocks are moving around on the axle perches. I still have the factory end links, I got them apart without destroying the Allen hole and reinstalled them. I don't feel any play but they do pivot quite easily if I push them around.
Any help would be appreciated, other wise the truck rides great with the Z71's and stiff shocks. Its not harsh at all.
