HVAC Mode Door
by KE7WOX » Fri Aug 31, 2012 5:56 pm
I need help from anyone who has fixed this before.
I'm trying to remove the HVAC mode door actuator, so I can at least try to manually force air up the dash while I fix it.
I can see 3 actuators, one is right above me, basically right above the knee panel. There's another one located right above a duct, one of the screws is accesible, but the connector and the other screw aren't. Both of these seem to have the same part number. A third one is located higher above the rest, more or less in line with the gas pedal, it has a P/N that is different by 1 digit.
My interpretation of the drawings is that I need the last one, but I'm not sure, can anyone confirm?
by NC_IslandRunner » Fri Aug 31, 2012 6:55 pm
I have to do the same thing, there is a pretty good write up on it on GMTNation.
by KE7WOX » Fri Aug 31, 2012 7:29 pm
There is one, but I can't seem to understand it completely :|, I found a post that has almost no info on another site but it has a photo explaining which one it is (and the photo shows the removed actuator with a PN that ends in 10, IIRC, that's the one I only have one of, so that should be the one. Giving it another try right now.
There is a writeup for re-indexing the unit, which I plan to do this weekend, once the damn unit is off.
by KE7WOX » Sat Sep 01, 2012 2:27 am
And how people say this is a 1 hr job is beyond my comprehension. So far I've gotten one of the 2 screws about a quarter of a turn out. I suspect that removing the accelerator pedal will give me more space, except I can't seem to figure out how to remove it, I removed 2 nuts but the assembly won't come off.
And the idea of not buying a GM again has been around my head for the past few hours.
by The Roadie » Sat Sep 01, 2012 10:49 pm
Everybody should have seen this pic of mine a hundred times.
by KE7WOX » Thu Sep 06, 2012 11:34 pm
It's all over the old OS, but until a few seconds ago, it made no sense. I couldn't visualize the part based on any other diagrams that are around the internet either, but now I've confirmed which one it is.
by rachyLTZ » Thu Sep 06, 2012 11:48 pm
well i have solved this problem by disconnecting the door mode actuator but for the life of me i could not see the white gear that you supposedly can move with a quarter, the actuator is busted it made a cliking noise but then :facepalm: again i could not locate that white plastic gear
rachyLTZ
